Irrationally exuberant
ChrisBennet's Avatar
3.6 conversion pump drive solution
Most 3.6 motors come with a power steering pump driven by the one of the cams. When you use a 3.6 in an earlier car you ditch the pump and install a cap ("camshaft block off cover") to cover the exposed cam drive. Patrick sells one of these caps for $89 and I think Porsche or PMS sells one. This was my lighter, cheaper Yankee solution:
I chopped the pump drive off the end of the cam and installed a cam housing plug for less than $3 (my cost).
-Chris
EDIT: The plug is Porsche part # 930 105 161 00
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-20-2004, 06:03 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Chris,
Are those caps simply pressed in or do you use some sort of sealant as well?
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 09-20-2004, 06:23 PM
Originally posted by smestas
Chris,
Pressed in with a little sealant (Loctite 518).
-Chris
Old 09-20-2004, 06:32 PM
beamonk's Avatar
Send a message via AIM to beamonk
Will this plug affect the cam's placement, i.e. place it out too far and screw up the chain alignment?
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 09-21-2004, 08:17 PM
The cam doesn't touch the plug at the end so it won't move the cam. The is the arrangement that, the left cam has, earlier cars had and 964's without power steering 964's (i.e. RS) have.
-Chris
EDIT: I'm not sure if the 964's have a blockoff cover or a different cam. I could be wrong on this.
Old 09-21-2004, 08:58 PM
Bandwidth AbUser
Jim Richards's Avatar
$3 vs. $89 or more? Way to go Chris!
Jim R.
Old 09-22-2004, 04:20 AM
Jeff Alton's Avatar
A very good solution indeed!!! Thanks for sharing.
Jeff
www.turn3autosport.com
Old 09-22-2004, 06:54 AM
davidl's Avatar
A good use for the power steering pump is to circulate the gearbox oil..cooler and or squirters..
Kind regards
Old 09-22-2004, 02:51 PM
Kind regards
That sounds like a great idea.
-Chris
Old 09-22-2004, 03:22 PM
so you have to remove cam to chop off the drive end or did I miss something. Great info, thanks! getting ready for 993 install in my 914/6.
Jim
Old 02-27-2005, 10:20 AM
Jeff Alton's Avatar
I am having John (camgrider) cut the drive off when he regrinds my cams. Thanks for the tip Chris!
Jeff
Old 02-27-2005, 10:27 AM
Jim
Yes, you just remove the cam and lop of the end so it looks like the other cam.
-Chris
Senior Member
john_colasante's Avatar
This seems nice, but is it a proven solution? How do you know it's not going to pop off when things get hot and start flexing?
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 02-27-2005, 11:09 AM
Jeff Alton's Avatar
The end plug for cylinders 1,2,3 never seems to pop off, so I would think having the same solution on both sides would work. This is the way all the pre 964 engines are.
Jeff
Old 02-27-2005, 11:48 AM
Senior Member
OK. Forgot there was one on the other side already. Nice.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 02-27-2005, 11:54 AM
