LinkBack | Thread Tools | Rate Thread |
3 restos WIP = psycho
Is it stupid to build a hot 2.0 on an original, numbers matching, 1R 'S' case?
The question says it all. I am convinced I need to buy an Al case, but I figured I'd solicit opinions.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
What kind of motor? Keeping it a 2.0L?
If you keep it a 2.0L or 2.1L I do not see a problem.... Now if you bore out the spigots, you may try to find a normal alum case.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
This has been the purpose of my research; Charles at LN has told me that he can get 87.5mm pistons and cyls into a stock 2 liter spigot. This would end up being a short stroke 2.4 if I went that way. Needless to say, I am worried that a 1R mag case would not be able to take a 225 HP 2.4L revving at 8K, stock spigot bores or not. It seems like you would know as well as most, though. Thoughts?
Andy |
Andy is correct: JE.
Your aluminum case would more than handle that HP from that 2.4L.
I read somewhere that 911 aluminum crankcase can handle upto 800 horsepower.
PRO Motorsports
I wouldn't build a short-stroke 2.4 on a 1R case. It will work, but will eventually tear itself apart. I've seen 2.7RS motors built on these cases though, but it's only a matter of time before the case is a paperweight.
If you insist on keeping the numbers matching, then keep it small bore. But no matter what, you should shuffle-pin just for longevity's sake, because even if you keep it a small-bore hot-rod, it will have to rev like mad to make any power.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Thanks Tyson, that is the exact answer I was looking for. You guys rock.
Home of the Whopper
I would shelf the original case regardless of which engine you decide to build. Why take the chance of damaging a case that significantly increases the value of your car? If you can afford it, shelf the entire engine.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
I'm going to shelf the case, P/C's and oil pump. The rest of the guts will most likely go to an aluminum cased motor unless I can somehow justify buying another 66mm crank and 2.0 rods, which I have been considering. It just seems like wasted money to me buying redundant, replaceable compnenents.
The Mag case will not handle the power and torque of the new 2.4..
Go with an aluminum case, and save the 1R case.
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
What about 2R/3R case? If you did all of the machine work (shuffle pins), how much life could you expect out of those cases? 7R would obviously be best of the mag cases...
Try not, Do or Do not
Just a historical note:
Almost all IMSA 2.5 liter GTU cars that ran Porsche engines used 7R cases because they offered the best service and reliability (not to mention weight savings.). I know of no front running teams that ran 2.0 aluminum cases for their race applications. I was there when they were built and I just can't remember one. If some of the other old timers remember one please chine in.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Addicted to Racing
The best rule of thumb I have heard is the mag case is good for 250 hp. If you plan on building more than that, then go alum.
Thanks Ed
Check out the parts for sale: http://www.demonspeedmotorsports.com PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer. See my list of current cars in my garage. |
IMSA 2.5 liter engines generally made very close to 300 hp
Andy |
