3 restos WIP = psycho
kenikh's Avatar
Is it stupid to build a hot 2.0 on an original, numbers matching, 1R 'S' case?
The question says it all. I am convinced I need to buy an Al case, but I figured I'd solicit opinions.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-06-2005, 01:28 PM
Plavan's Avatar
What kind of motor? Keeping it a 2.0L?
If you keep it a 2.0L or 2.1L I do not see a problem.... Now if you bore out the spigots, you may try to find a normal alum case.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 09-06-2005, 06:12 PM
kenikh's Avatar
This has been the purpose of my research; Charles at LN has told me that he can get 87.5mm pistons and cyls into a stock 2 liter spigot. This would end up being a short stroke 2.4 if I went that way. Needless to say, I am worried that a 1R mag case would not be able to take a 225 HP 2.4L revving at 8K, stock spigot bores or not. It seems like you would know as well as most, though. Thoughts?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-06-2005, 06:41 PM
from where?
Old 09-07-2005, 09:07 AM
KobaltBlau's Avatar
Originally posted by blue72s
from where?
This is charles at LN engineering. his company makes the "nickies" cylinders and uses JE pistons, I'm sure this is what kenikh is referring to. not mahle stuff.
Andy
Old 09-07-2005, 09:16 AM
kenikh's Avatar
Andy is correct: JE.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-07-2005, 09:18 AM
Plavan's Avatar
Your aluminum case would more than handle that HP from that 2.4L.
Chad Plavan
Old 09-07-2005, 10:04 AM
kenikh's Avatar
Actually, I was referring to the mag case; I don't have an aluminum case yet. I know the aluminum cases are pretty much bulletproof since you can make a 300HP 2.8 on them without worries.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-07-2005, 10:27 AM
I read somewhere that 911 aluminum crankcase can handle upto 800 horsepower.
Old 09-07-2005, 12:21 PM
kenikh's Avatar
The only caveat being that the case is properly prepped (shuffle pins).
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-07-2005, 12:32 PM
PRO Motorsports
Tyson Schmidt's Avatar
I wouldn't build a short-stroke 2.4 on a 1R case. It will work, but will eventually tear itself apart. I've seen 2.7RS motors built on these cases though, but it's only a matter of time before the case is a paperweight.
If you insist on keeping the numbers matching, then keep it small bore. But no matter what, you should shuffle-pin just for longevity's sake, because even if you keep it a small-bore hot-rod, it will have to rev like mad to make any power.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-07-2005, 12:54 PM
kenikh's Avatar
Thanks Tyson, that is the exact answer I was looking for. You guys rock.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-07-2005, 01:22 PM
Home of the Whopper
I would shelf the original case regardless of which engine you decide to build. Why take the chance of damaging a case that significantly increases the value of your car? If you can afford it, shelf the entire engine.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 09-08-2005, 08:32 PM
kenikh's Avatar
I'm going to shelf the case, P/C's and oil pump. The rest of the guts will most likely go to an aluminum cased motor unless I can somehow justify buying another 66mm crank and 2.0 rods, which I have been considering. It just seems like wasted money to me buying redundant, replaceable compnenents.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-08-2005, 08:40 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
The Mag case will not handle the power and torque of the new 2.4..
Go with an aluminum case, and save the 1R case.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 09-20-2005, 10:32 AM
kenikh's Avatar
What about 2R/3R case? If you did all of the machine work (shuffle pins), how much life could you expect out of those cases? 7R would obviously be best of the mag cases...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-20-2005, 06:02 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Just a historical note:
Almost all IMSA 2.5 liter GTU cars that ran Porsche engines used 7R cases because they offered the best service and reliability (not to mention weight savings.).
I know of no front running teams that ran 2.0 aluminum cases for their race applications.
I was there when they were built and I just can't remember one.
If some of the other old timers remember one please chine in.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-14-2005, 09:31 AM
Addicted to Racing
edbaus's Avatar
The best rule of thumb I have heard is the mag case is good for 250 hp. If you plan on building more than that, then go alum.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 10-19-2005, 08:09 AM
IMSA 2.5 liter engines generally made very close to 300 hp
Henry Schmidt
Ph: 760-728-3062
Old 10-19-2005, 10:33 AM
KobaltBlau's Avatar
What was the tear-down interval, I wonder? It would be even more interesting to know how often (if ever) the cases were replaced in terms of hours, on average. Maybe never, who knows.
Andy
Old 10-19-2005, 01:22 PM
