Machining top end price
What is a ball park price for all the machine work that needs to be done when doing a top end rebuild?
Just normal wear on a 1980SC. Nothing burnt, bent, broken.
Thanks.
Ron.G
Old 03-04-2005, 06:28 AM
I think I paid around $900+. But, I had to have a few valves replaced, flywheel and pistons balanced, rods shot peened, etc.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 03-04-2005, 06:42 AM
Thank you.
Old 03-04-2005, 06:46 AM
addictionMS's Avatar
on the other end of the scale, if you do rings, and find a lot of valves are bad, could be upwards of $3K+
a 3.2 I am working on now had $1600 in head work alone.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 03-04-2005, 07:04 AM
Irrationally exuberant
ChrisBennet's Avatar
Around $400 for machining including new guides, spring test and assembly at correct spring height - ready to go when you get them back.
Add another $5-600 for new valves and replacing a few exhaust studs.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-04-2005, 07:31 AM
Somewhere in the Midwest
MotoSook's Avatar
Chris, who did you use?
Old 03-04-2005, 07:49 AM
Atlantic Enterprises 856 589-5577. They're in NJ. I've been sending Bob heads for years.
-Chris
P.S. If you don't want the candy, tell Bob to send it to me.
Old 03-04-2005, 07:55 AM
MotoSook's Avatar
Great! Thanks Chris, I've got a couple sets of heads that need work...does that mean two orders of candy for you (not that I know waht candy you are talkign about)
Old 03-04-2005, 08:00 AM
stevepaa's Avatar
http://www.competitioneng.com/Welcome.htm
Clean,Inspect & Evaluate C/2 Heads. $75.00
> Replace Guides $204.00 Plus Parts @ 6.25 Ea.
> Resurface ( If Necessary) $240.00
> Valve Job w/ assembly $330.00 Plus parts.
> Grind & Polish Rockers.$15.00 Ea. If bushings are worn past spec. Add
> $4.00 Ea. Plus bushings @ $3.50 Ea.
I had Ted Robinson, local, do mine about same price. Bruce Anderson recommended Ted.
Ted Robinson
German Precision
Porsche machining
1270 Lawrence Station Road #H
Sunnyvale, CA 94089
Phone 408/747-0728
Fax 408/747-0782
steve
old rocket inguneer
Old 03-04-2005, 08:40 AM
Bob puts a bag of candy in with your heads when he sends them back. Usually Mary Jane's.
The CE appears to charge $774 for the same thing A.E. charges about $400 for. All Bob does are heads so it possible that he's done more 911 heads than the Porsche specialized machine shops.
-Chris
Old 03-04-2005, 10:24 AM
MotoSook's Avatar
Chris, I had a hunch that was what Bob did..shows his character...I like!
Old 03-04-2005, 10:31 AM
MotoSook's Avatar
Just got off the phone with Bob...great guy! Thanks Chris.
Old 03-04-2005, 10:45 AM
