How do i remove the sprocket behind can gear?
I removed the cam gear from my 964. But how do I remove the sprocket flange (#15 see pic)? It seemed stuck. Do I use a gear puller?
thanks,
anthony
Old 03-07-2005, 07:46 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Two rolling head bars (lady fingers) or and gear puller will work fine. The gears should not be very tight.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-07-2005, 07:52 AM
My cam gear popped off easily with a gear puller, but the woodruff key was troublesome. I had to push down interior end enough to get front to pop up enough to lever up with a small screwdriver. All this was after the key\cam soaked an evening in WD-40. I hope yours pops out with ease!
Old 03-07-2005, 09:53 AM
just set a screwdriver blade into the front of the key and tap with a hammer lightly and it rolls right out. grab it with some dykes to finish the job.
206 637 4071
Old 03-07-2005, 10:08 PM
I used a gear puller, and pulled it out. This board is fantastic.
thanks,
anthony
Old 03-07-2005, 11:35 PM
do the dykes mind being used in this fashion?
Old 03-08-2005, 12:10 AM
Doug Steinel's Avatar
Mark,
As long as you are rough, they don't mind.
77 911, 3.0L
Old 03-08-2005, 03:50 PM
