Another head stud question
What is the best head stud for a stock 3.0 1980SC?
The reason I ask is because the motor is corrently getting a top end rebuild and I took a magnet to the new studs that were put in by the shop and they are not magnetic. I'm guessing there Dilivars. Is this a bad thing? |
I'd use steel studs on the bottom just like the top. Yes, Dilivars are a bad thing.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Irrationally exuberant
I wouldn't remove the (expensive) Dilivar's if they were already installed. Assuming they are new (not some old studs the builder had laying around) I think they will last another 20 years.
ARP studs are stainless and some stainless steels are non-magnetic. (I just checked, Raceware studs are magnetic.) -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks Guys.
The studs are all ready in so maybe I won't bother the tech. It's just that ALL of them are non magnetic top and bottom. Is this okay?
Silver 1980SC Euro coupe |
What don't you ask you builder what studs (part #) he used?
-Chris
Are they painted in the middle? If so they may be Dilivar, if not they may be ARP or some other stainless stud. Are they shiny?
My 930 has Dilivar studs that looked good, but they might have been replaced a few years before I got it. So they might be good for 20 years. On the otherhand I've seen a 78 SC that had all the Dilivar studs broken or cracked.
They are all black. They look like they maybe painted with appoxy or something.I'll ask today.
Try not, Do or Do not
I may be some-what biased but I recommend SUPERTEC head stud kits. They are for sale through our host.
Check the Pelican Parts under head studs.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
painted dilivars should be fine for at least 20 years. wouldn't have been my choice, (steel), but you'll be ok.
Thanks John.
