Forced Induction Junkie
WERK I's Avatar
Originally posted by john walker's workshop
lets not forget the thread that morphed into this one, pictures and all.
Loctite 574 thickness
Spot on, John! There are only two scenarios that would have caused this, neither of them good.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 04-16-2005, 05:00 AM
stevepaa's Avatar
well my Porsche 964 was totaled with 80K miles on engine three years ago and no leaks. I used the red loctite 518 shown in my earlier posr
steve
old rocket inguneer
Old 01-16-2017, 09:34 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Hmm, I thought we are not supposed to use a silicone based sealant (dirko) for the case, just incase, sorry, pund not intended, may get inside the case and the oil circulation system, right?
I know it will be lessened if one is careful but why take a chance?
'85 Carrera Targa
PCA/POC
Old 01-16-2017, 09:41 PM
Targa_PB_78_SC
mike sampsel's Avatar
Revival of an old thread for dirko by newbie.
From what I've read in this forum, the sealing of the case with dirko would allow for any silicone dregs to go to the oil filter via the suction of the oil pump. So it is not a concern and won't get into the oil sprayers (cam and pistons for example). Of course I'm a rookie looking for the easiest solution.
A.) One which yields no leaks and
B.) Easy to apply with a reasonable setup time
Seems like dirko is a good one. Although, I've been impressed with permatex ultra gray too. Dirko has more info herein on how to apply though. I see the 1184 is popular also with accolades from Henry of supertec, seems it only gives me 20 minutes though?
Old 07-02-2019, 06:35 AM
Stick with Loctite 574. Don't reinvent the wheel. Most leaks are caused by clumsy setup and mating of the case halves by inadvertently touching the case parting line and disturbing the sealant.
Old 07-02-2019, 06:48 AM
"seems it only gives me 20 minutes though?"
It's a lot less than that. I used it once on the case seam with no leaks but went back to 574 because it skins too quickly for my liking. It's great for all the other surfaces and gaskets though that can be assembled quickly but I don't like to be rushed when putting the cases together.
Old 07-04-2019, 04:03 AM
Here's the thing. You can ask 4 different experienced professional 911 engine builders and get 4 different answers so pick the one you trust because his solutions more than likely work because he's not going to want to tear down a motor under warranty.
If you don't know who to ask some suggestions are
Henry Schmidt
Catorce
John Walker
Wayne
There are several others also
Stick with whatever they say to the T and that's your best chance for success
Just my opinion
Tony
Old 07-05-2019, 04:10 AM
