Cyl. Head & knock sensor - Megasquirt
Help,
I’m looking for some pictures of a #3 cylinder head from the 84-89 vintage 3.2 Carrera. I plan to machine an SC head for the cylinder head temperature sensor, the pictures should get me close enough.
Reason: I’m planning (hoping I can figure out how) to use MegaSquirt F.I. down the road…
Also, I’m looking at knock sensor(s) what sensor(s) to use and where to locate it/them? Any insight here would be appreciated.
Scott
75 911S Coupe 3.4 Twin Plug - ITB - MegaSquirt
84 Carrera Coupe M491
Old 04-11-2005, 09:42 AM
dweymer's Avatar
I have heard that the aircooled engines generate too much internal noise for knock sensors to work reliably. No first hand knowledge though.
Donnie
Currently Porsche-less.....
Old 04-11-2005, 01:27 PM
3 restos WIP = psycho
kenikh's Avatar
3.6s have them...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-11-2005, 01:29 PM
350HP930's Avatar
Yeah, thats BS.
If you are going to use a single sensor, the best place would be on the top of the case, under the cooling shroud. Locating it near the center of the crank should allow it to hear knock from any of the cylinders pretty well.
Right now I am concidering whether I will connect mine using one of the case perimeter bolts or whether I will machine the case for a good mounting point on one of the case main bearing webs.
Old 04-11-2005, 04:08 PM
dweymer's Avatar
Glad to know that, as wanted one for a turbo app.
Donnie
Old 04-11-2005, 05:22 PM
350HP930's Avatar
I too am planning on taking the MSII with knock control and EDIS coil packs route.
When I just had CDI ignition I was using a J&S safeguard unit that provided individual cylinder knock control.
The condition of my engine parts at 130K miles was a testimony to its effectiveness.
Old 04-11-2005, 05:32 PM
kenikh's Avatar
I've heard good things about the J&S. Any chance it can be used in conjunction with the MegaSquirt? Per cylinder knock control is pretty impressive.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-11-2005, 06:29 PM
350HP930's Avatar
It could since it intercepts and delays the inductive pickup signal so it could be used with the CDI trigger. Unfortunately I can't use mine with the EDIS setup.
I am selling mine for $200 if you want a good used unit.
Old 04-11-2005, 06:39 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Here are a couple of pics of a #3 head. I don't know if these will help you, but is all that I have that shows the head temp sensor.
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 04-11-2005, 07:23 PM
I guess it would help if I attached the pics, right?
Good luck!
Ralph
Old 04-11-2005, 07:25 PM
Thanks for the Pic's Ralph that should do - Nice heads!
So who knows where the Knock Sensor(s) are mounted on the 3.6?
Scott
Old 04-12-2005, 09:42 AM
Irrationally exuberant
ChrisBennet's Avatar
Scott
3.6's have 2 knock sensors, one 1-3 and another for 4-6.
A "bridge" is bolted to the a boss on each cylider (one bridge per bank of 3 cylinders) and a knock sensor is attached to the bridge.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-12-2005, 10:43 AM
dweymer's Avatar
Chris,
Got ahold of Bill at Atlantic, thanks for the contact info.
Don
Donnie
Old 04-12-2005, 10:51 AM
kenikh's Avatar
For what it's worth, here's a PET diagram of the part (number 9):
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-12-2005, 10:59 AM
Chris,
Don
It's Bob, Bob Hirst at Atlantic. Tell your friends. One more referal and I get a steak knives. ;-)
-Chris
Old 04-12-2005, 11:13 AM
dweymer's Avatar
yes Bob, sorry; and I am keeping my candy.
Donnie
Old 04-12-2005, 12:23 PM
