2.7RS-part1
Hello
here are a few sots of my starting project :2.7RS rebuilding...
this is the case...
the workbench
another view...
the stock pistons are in a very good shape...(10000kms)
cylinders too, (you can see the "cross")
the only problem i had is with head stud removal...(your advice to fix it ?...)
the others are nice...
all comments are welcomed, especially for cleaning the mag case...
Philippe
Old 03-24-2005, 01:43 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Is that a timecert that has ripped out? The last picture looks like it had timecerts in it, but can't be sure.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-24-2005, 01:48 PM
Hi Tim,
you give me a doubt, i'm not sure timecert are in the case, i didn't give attention...
i don't think i noticed something during head stud removal
Old 03-24-2005, 01:57 PM
Hello
I finally checked the threads this morning, the aren't any timecerts installed, by the way, may you tell me the diameter to drill to install them , and where to get them ?
Philippe
Old 03-25-2005, 09:29 AM
dtw dtw is offline
GAFB
Installation of timeserts, or even better, case savers, is best done by a machine shop. They jig up the case so that the inserts are installed level and on-center, so your studs all align with the cylinders properly.
If you do decide to do it yourself, call any of the race or machine shops mentioned on this board for a source.
Several BMWs
Old 03-25-2005, 09:52 AM
Hello
a machine shop will do the job....
i was told the case savers were not recommended on mag cases ?
advices welcomed
best regards
Philippe
Old 03-25-2005, 02:34 PM
