2.7RS-part1
Hello
here are a few sots of my starting project :2.7RS rebuilding... this is the case... the workbench another view... the stock pistons are in a very good shape...(10000kms) cylinders too, (you can see the "cross") the only problem i had is with head stud removal...(your advice to fix it ?...) the others are nice... all comments are welcomed, especially for cleaning the mag case... Philippe |
Is that a timecert that has ripped out? The last picture looks like it had timecerts in it, but can't be sure.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Hi Tim,
you give me a doubt, i'm not sure timecert are in the case, i didn't give attention... i don't think i noticed something during head stud removal ??
Hello
I finally checked the threads this morning, the aren't any timecerts installed, by the way, may you tell me the diameter to drill to install them , and where to get them ? Philippe |
GAFB
Installation of timeserts, or even better, case savers, is best done by a machine shop. They jig up the case so that the inserts are installed level and on-center, so your studs all align with the cylinders properly.
If you do decide to do it yourself, call any of the race or machine shops mentioned on this board for a source.
Several BMWs |
Hello
a machine shop will do the job.... i was told the case savers were not recommended on mag cases ? advices welcomed best regards Philippe |
