Wer bremst verliert
JohnJL's Avatar
Are case through-bolts wear items?
Is it necessary to replace case through-bolts? Haven't read about them breaking and kind of spendy at $34 each.
Thanks!
John
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-29-2005, 05:54 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
No, generally not necessary, but do replace the o-rings! These should be included in your new gasket set.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 04-29-2005, 06:33 AM
Nitrometano's Avatar
That is a reusable item.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 05-26-2005, 08:09 PM
Insane Dutchman
What would you look for in terms of wear/mileage/damage/corrosion before you replaced them? I have an engine with 301,000 miles on it which will serve as a donor for many of the parts that will go with my brand new, zero miles engine case...I'd hate to put all sorts of new stuff together then have an old through bolt fail....
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 05-27-2005, 08:44 PM
Insane Dutchman
What about replating them....to make them look pretty a nice zinc dichromate plate job would be easy to do....any issues? Or is there some fancy schmantzy coating on them that is a "do not disturb" sort of thing?
Dennis
Old 05-30-2005, 08:18 PM
Dennis
I'm not sure that I would plate the through-bolts themselves (have never seen it done), but you can certainly plate the acorn nuts on the other side without any sort of ramifications:
Ralph
Old 05-30-2005, 09:50 PM
