Send a message via Yahoo to Groovy911SC
Turn engine over without engine mount... bad idea?
I'm trying to locate an oil leak in the back of the engine. Last week, without removing the engine mount, muffler etc, I assumed I just made a mistake when rebuilding the engine. After looking at the area in question behind the crank pulley, that area is dry. No oil residue. The intermediate shaft cover is another story. It is soaking in oil, particularly seeping from the studs. I know oil flows down due to gravity... haha, so I really wanna make sure exactly where the leak is. IF I douse the area in talcum powder and turn the engine over a bit perhaps the leak will reveal itself.
My question is should I reconnect the engine mount to do this? Without the engine mount connected I can readly see the areas of concern.
As always any help will be appreciated!!!
1980 911SC
One day will be "G" Stock PCA racer
Old 05-01-2005, 11:36 AM
Done.
1980 911SC
Old 05-02-2005, 09:56 AM
Nitrometano's Avatar
You can put a jack or tower to suppor the engine, then you remove the engine mount bracket.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 05-26-2005, 08:06 PM
