Air Medal or two
afterburn 549's Avatar
996 dizzy to a 911??
Can a 996 or 964 dizzy be made to drop a 911 ? I relize they go oposit directions so...can a 911 gear be put on and some stuff done to it so the case dose not have to be split??????
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-02-2005, 06:06 PM
Irrationally exuberant
ChrisBennet's Avatar
Just some quick data points off the top of my head (really should be working):
996 - do they even have distributor?
993&964 - turns clockwise, also fits in a 3.2 motor
3.2 - turns clockwise
3.0SC and 3.3 Turbo - the only ones that turn counter clockwise to my knowledge
2.7 Sorry, dunno
Some time before the 3.0, the distributor hole/body was smaller but I don't know when that happened.
Hopefully someone knowledgable will correct my memory.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-03-2005, 08:17 PM
Air Medal or two
well I was thinking of one of those dual piggy back dizzys....what ever they fit on,,I am sure they will drop in if the gears are changed...but I am tring to see if it can be done by just changing the gear on the dizzy and run it backwaeds with some other mods.........thanks!
Old 05-03-2005, 08:36 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
are you thinking of the twin rotor 964 dizzy? if so check out ralphs thread on his 3.5 build. he used one for twin plug.
74 911s neverending story. two feet and a jetta for now.
Old 05-03-2005, 11:26 PM
BURN-BROS's Avatar
Afterburn, The engines that have their dizzys rotating the oposite way require the case to be split and the gear on the crank replaced. Not the gear on the dizzy. Do not attempt to change direction of the dizzy as it will not perform as expected.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-04-2005, 06:56 AM
Hi:
The 3.6 dual-dizzy can be modified to work in your 2.7, but you'll need to change the crank gear to a 3.6 one. Both distributors turn the same direction, but the 3.6 gear has a different pitch.
We do these all the time.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-04-2005, 09:25 AM
Air Medal or two
thanks Steve....not what I wanted to hear,but truth is better then fiction.Think I will just save my cash for SDS then, as I do not want to split the case for a caveman set up.
Old 05-04-2005, 10:15 PM
