Nitrometano's Avatar
I need to resurface the rocker arms because new camshafts will be installed, do you know a shop that can do this job?
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 06-01-2005, 08:12 PM
I measure the crankshaft and this is what I get:
Main Bearings:
1) 57.97
2) 59.98
3) 58.98
4) 59.96
5) 59.96
6) 56.97
7) 57.97
8) Nose bearing not meassure yet.
Rod Bearings:
1) 53.05
2) 52.96
3) 53.05
4) 52.96
5) 52.99
6) 52.98
I think that the crankshaft are out of specification. What is your opinion?
Intermediate shaft:
24.98 (pulley side)
23.94 (oil pump side)
I dont know the correct meassure for this part. Let me know if the shaft is good or not.
The cylinders are all between specifications. They are Mahle and they are from Grup 6. I can re-reing this engine? The cylinders are Nikasil or Alusil?
1972 911T
Old 06-01-2005, 08:26 PM
Irrationally exuberant
ChrisBennet's Avatar
Main Bearings:
1) 57.97 <--
2) 59.98
3) 58.98 <--
4) 59.96
5) 59.96
6) 56.97 <--
7) 57.97 <--
The spec for mains is 59.97mm to 59.99mm so 1, 3, 6, 7 are out of spec by exactly 1.00, 2.00 or 3.00mm. I bet there is a good chance that you read the mic. wrong and they are perfect. What's the chance of them being out of spec by an exact multiple of 1mm?
Rod Bearings:
1) 53.05 <--
2) 52.96
3) 53.05 <--
4) 52.96
5) 52.99
6) 52.98
The spec for the rod journals is 52.97-52.99. #1 and #3 are bigger than spec.
Frankly, I am not very good at measuring or I should say it takes me 5 times as long as a machinst would. I just don't get enough practice. I know I get some odd measurements when I'm very tired... I bet there is a good chance that you've "pulled a Chris" and misread the mike or something and your crank is fine.
I've got my fingers crossed for you!
I measure in 2 places, 90 degrees apart, on every journal.
The motor I'm working on now had a crank with a bad rod journal and the customer was able to get a good used crank for something like $800 I think.
Kinda bites that the machine shop charged him $125 for "inspection and micropolishing" and never told him it was so out of spec you could tell just by looking at. Probably an honest mistake. There is a lesson there though; trust no one, measure everything yourself.
Remeasure, maybe it's not as bad as you thought.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-01-2005, 09:14 PM
Thanks for the info Chris, I will take the meassures again.
1972 911T
Old 06-05-2005, 10:28 PM
I measure again. The guy in the machine shop measure again and the crankshaft is out specs. It will grind it. I know if not recomendable, but there is not another option.
1972 911T
Old 06-09-2005, 10:37 PM
Sorry man.
Old 06-10-2005, 05:39 AM
BReyes's Avatar
As it relates to your crank, I recommend you send the crank to a machine shop specializing in Porsche. The nitriding process is a necessary process, few can do adequately.
Regards,
Bernard
Old 06-10-2005, 09:59 AM
