factory steel head stud reuse
Hi
may you give me your opinion:
shall i reuse the steel head studs after teardown ?
i mean, they could have been a bit stressed during tear down operation (using snap on removal tool).
what do you think about it ?
(case savers to be installed in a mag case)
best regards
Philippe
Old 06-05-2005, 05:00 AM
Air Medal or two
afterburn 549's Avatar
the steel ones are now pronouced "better" and are cheap enough..replace,cheap insurance.......very hard to do in car.......tear dwn again.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-05-2005, 08:17 AM
if their threads didn't get damaged from removal, i see no reason why they could not be reused.
206 637 4071
Old 06-05-2005, 08:29 AM
Air Medal or two
the only thing I am thinking is if they have been there 10 yrs or so....might be a good time to do it
Old 06-05-2005, 09:34 AM
Unregistered
sammyg2's Avatar
no reason to replace em unless they are damaged.
If they haven't seen extreme corrosion or over-stressing they will last longer than the car.
Old 06-05-2005, 12:48 PM
Air Medal or two
well John for sure ought to know, I was under the thought they sort of had a t.b.o.
Old 06-05-2005, 01:16 PM
after you use a bench grinder wire brush on them, they usually look like new. any pitted ones should obviously be replaced.
206 637 4071
Old 06-05-2005, 03:52 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Walt at CE using the same procedure, but media blasts the studs. If they look ok he paints the studs (not threads) to prevent rust/corrision, etc.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 06-05-2005, 07:38 PM
thanks
Philippe
Old 06-06-2005, 03:06 AM
