Still Doin Time
asphaltgambler's Avatar
Unhappy You won't believe why it blew up...........
Readers Digest of my story. Last year we were in the market for our first 911. Being a European tech by trade with many years under my belt AND good advice from P-car exclusive techs I was ready to "git one"
After many dissapointments, decided on a nice '85 Targa w/95K that was not perfect, but was priced under market with small items I could address along the way.
After @1200 mile and two months, no issues until one Sunday road trip the engine gave way in a serious manner. Now I'm bummed out big-time. Spare time and $$ got in the way until recently when I dropped the engine for a complete rebuild / hop-up.
Split the cases Friday night and much to my surprise the rod cap was off and bent beyond belief; piston, cylinder, layshaft ruined. The case and crank were damaged, but repairable.
The cause???????? Believe it or not the connecting rod nuts FELL OFF allowing the rod cap to progressively work loose and parts went flying!! At first I thought the rod bolts had failed. Closer inspection revealed what was perfect threads on the nuts and the bolts. They had just backed off until they fell off!! UN-F__KING BELIEVABLE !!!
That issue destroyed a really good 3.2. The prior leak down was good and the bearings looked almost new.
Anyone else seen this?? I'm baffled
Pics of the carnage will follow soon.
Old 06-05-2005, 08:29 AM
Jeff Alton's Avatar
This may have been cuased by an over rev earlier in the cars life causing the rod bolts to stretch. The nuts would then not be torqued and could possibly come loose?? Maybe? Just a possibility
Jeff
www.turn3autosport.com
Old 06-05-2005, 10:44 AM
I know how you feel. About a month ago I did a cross country trip from Texas, where I bought the car. I initially thought of having my new purchase shipped back to Cali., but I decided to drive it back instead, in order to "bond" with my baby. Everything went well, the 915 tranny though sluggish in the city performs well on the freeways. The K-27 upgrade, which I paid the PO to upgrade before title sign over, allowed the 3.3 to breath and spool up quicker. I cruised I-10 through New Mexico and Arizona enjoying the pre-summer desert weather when just 30 miles outside the California - Arizona border, I heard a pop/clunk from he back and i see from my side mirrors black smoke eminating from the rear. My dream car has become my nightmare. How was this so? The PO provided paperwork to doument the rebuild from TRE about 10K miles ago. Didnt expect the engine to go out so soon. To make a long story short, I had found a carrier and had shipped back to NorCal to begin the engine rebuild. Heck, I was only behind the steering wheel for about 18 hours, now I gotta spend months in the garage before i can get back behind the wheel. Needless to say, my wife was livid when her first images of the car was on a flatbed. Once i got over the initial shock and heartache, I actually look forward to dropping the engine and working on it. I guess in some perverse way, it's all about the car. Driving it or working on it, it's all the same, you gotta love it. He he he, just got to convince my boss for some overtime......I want my parts! I will be documenting my rebuild on another thread.
'76 3.3 K-27 She's almost 30, but she still turns me on!!!
Old 06-05-2005, 11:51 AM
adomakin's Avatar
I think Jeff hit the nail on the head. 3.2's have got a rep for rod bolt faliure. over revs are a real danger as the bolt stretches, then the nut is effectively backed off and loose. ends up either failing though a floating rod cap or because the nut comes off. nitemare. what else is mangled? have you got any pics?
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 06-05-2005, 02:28 PM
350HP930's Avatar
If the nuts had time to back off I am surpised you didn't hear it knocking before it threw the rod.
Old 06-05-2005, 03:05 PM
Jeff Alton's Avatar
350 has a good point. It would seem they would be loose for a little while and there should be a small reduction in oil pressure as well I would think.
Jeff
Old 06-05-2005, 05:37 PM
Still Doin Time
Oh it was knocking alright, but at that moment we were in the middle of deliverance-ville, no shoulder to pull off on, it was a old 4 lane divided hwy. Initially it sounded just like the timing chain tensioner had collasped, but quickly grew worse, then........pop just as we found a place to pull over.
Just the stuff I listed above was damaged. I was planning up a 3.4 build so the ruined piston is no big deal. I've already puchased one good used rod and found a useable cylinder this weekend. The case damage was contained where the web between mains 3-4 join. I can have it Tig-welded back. It broke the laysahft and bent the connecting drive tube to the oil pump. So basically could have STILL been a lot worse. That crank is just slightly damaged on # 5 rod throw, it's fixable most likely 1st undersize.
I'll try to have pics next week.
Old 06-05-2005, 07:06 PM
Still Doin Time
By the way ROMY.............that REALLY sucks!!
Old 06-05-2005, 07:08 PM
adomakin's Avatar
i know someone in the states who has a good used layshaft if you need one
Andy
Andy
Old 06-05-2005, 11:00 PM
Irrationally exuberant
ChrisBennet's Avatar
Jeff
I lost a rod bearing once and to my surprise the oil pressure didn't seem to drop at all. "Oil pump, strong like bull!"
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-06-2005, 03:51 AM
Still Doin Time
Wayne, WAAAY ahead here. Your book is my bible and this build will be my P-car term final. This board has been extremely helpful to me in the planning stages.
Old 06-06-2005, 05:44 PM
Jeff Alton's Avatar
Chris, wow, that surprises me, but I am easily surprised!!
Jeff
Old 06-06-2005, 06:27 PM
David's Avatar
I see another Loctite on rod bolts thread starting
Old 06-06-2005, 07:17 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, thanks for bringing that up. I really feel that putting the Loctite on the rod bolts buys you some extra miles when you might need it. This is a perfect example, where the torque was lost on the bolts and the dang thing fell right off. That probably would not have happened if the bolts were tightened with some Loctite...
-Wayne
Old 06-07-2005, 03:08 AM
stevepaa's Avatar
Well, just a simple question. How do you put Loctite on ARP rod bolts with the lube applied to the threads?
steve
old rocket inguneer
Old 06-07-2005, 09:47 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
According to the book written by wayne, your not supposed to put any lube on the threads, just the locktite. Therefore the locktite acts like a thread lube.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-07-2005, 10:38 AM
Not that I'm advocating Loctite on rod bolts but if you were worried about getting proper fastener tension you could use the bolt stretch method instead of using torque angle method.
Unlike the factory bolts, the ARP's may be reused. Of course if you Loctite them that might be a problem...
I don't know what the stretch spec is for factory rod bolts or even if there is one. I suppose one could come up with a rough value by measuring the stretch on few rod bolts tightened using the factory method.
The 9mm factory rod bolts have a well know reputation for stretch-leading-to-failure and this perhaps justifies the Loctite "solution". I am unaware/ignorant of any problems with ARP rod bolts in this regard.
-Chris
Old 06-07-2005, 11:03 AM
stevepaa's Avatar
Yeah, I used the stretch method after trying the torque method. Stretch is the way to go. So I guess you could use loctite if one did the stretch method.
steve
old rocket inguneer
Old 06-07-2005, 01:13 PM
OK, so which Loctite is recommended? Is this problem common on the 2.4L motors? I am about to start assembly with new rod bolts & will use the stretch method. Thanks.
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 06-10-2005, 07:12 AM
