Question Can someone identify this switch
Can someone identify this switch - it's attached the oil breather cover?
I'm guessing it's a oil temp switch. But it seems to have been disconnected long ago. I'm wondering if I should try to reconnect it while the engine is out... Any advice is much apprecriated? Thanks!
'82 911SC
Old 08-05-2005, 07:44 PM
On my PET program this is 930 606 117 00 temperature switch...I think this is used to turn on oil cooling fans, at least I think that's what it does on my 89 3.2, I'd need to check the elec. schematic to be sure on that.
Since I have a Carrera and yours is an SC you may want to check other sources. On the 89 the pn is 118 instead of 117. I replaced mine when I did the top end.
Hope this helps.
-h
Sold: 1989 3.2 coupe, 112k miles
Old 08-08-2005, 06:19 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
It appears as though there is a wire behind the temperature switch that is terminating on the stud? I believe this wire should be connected to the temperature switch. I would highly suggest you replace this switch with a new one, they are rather inexpensive and it appears as though there is some oil gaining access just underneath the switch.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-08-2005, 08:20 AM
Irrationally exuberant
ChrisBennet's Avatar
If my crappy memory serves, my buddy Mark (Pelican "Hald") traced that switch to a relay that had something to do with the heater blower.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-08-2005, 10:56 AM
3.2 CAB's Avatar
Ditto on what Chris said, it is a temp. switch that makes the rear blower fan come on when the engine temp. gets too hot.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 08-09-2005, 04:28 AM
