Can someone identify this switch - it's attached the oil breather cover?
I'm guessing it's a oil temp switch. But it seems to have been disconnected long ago. I'm wondering if I should try to reconnect it while the engine is out... Any advice is much apprecriated? Thanks!
'82 911SC |
On my PET program this is 930 606 117 00 temperature switch...I think this is used to turn on oil cooling fans, at least I think that's what it does on my 89 3.2, I'd need to check the elec. schematic to be sure on that.
Since I have a Carrera and yours is an SC you may want to check other sources. On the 89 the pn is 118 instead of 117. I replaced mine when I did the top end. Hope this helps. -h
Sold: 1989 3.2 coupe, 112k miles |
JOT MON ABBR OTH
It appears as though there is a wire behind the temperature switch that is terminating on the stud? I believe this wire should be connected to the temperature switch. I would highly suggest you replace this switch with a new one, they are rather inexpensive and it appears as though there is some oil gaining access just underneath the switch.
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Irrationally exuberant
If my crappy memory serves, my buddy Mark (Pelican "Hald") traced that switch to a relay that had something to do with the heater blower.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Ditto on what Chris said, it is a temp. switch that makes the rear blower fan come on when the engine temp. gets too hot.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
