1972_911T's Avatar
Alusil Or Nikasil
Can you tell if a 3.0 engine has alusil or nikasil cylinder by examining the barrels from underneath or does it require a strip down?
Old 08-10-2005, 10:18 AM
1972_911T's Avatar
Also what cylinders did the 3.2's use it states in waynes book that on the 2.7 and 3.0 it was pot luck as to which ones you got but does'nt say for the 3.2's.
Old 08-10-2005, 12:16 PM
PRO Motorsports
Tyson Schmidt's Avatar
You can't tell from looking underneath.
Even if they are Mahle, they may still be Alusil. You have to have the barrel out of the car and look at the inside. Or use the magnet method if you don't have enough experience to tell by eye.
3.2's were all Nikasil.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-10-2005, 01:20 PM
1972_911T's Avatar
Ok thanks for that! Im trying to decide wether to upgrade to a 3.2 or a 3.0, and carnt make my mind up so im trying to arm myself with as much info as I can about both engines to help me decide. Are the 3.2's generally speaking more reliable and less prone to faults than the 3.0 or are they about the same. I have read somewhere about rod bolt failures in the 3.2 and I can imagine this is probably going to as good a right off the engine, how common are these? and is it just a chance occurence or is it badly maintained engines that have these faults.
Old 08-10-2005, 01:43 PM
PRO Motorsports
If you can swing it, definitely go 3.2.
But if you get a great deal on a 3.0, then jump on it. CIS can be a pain, and parts are expensive. The DME on the 3.2 is much simpler and cheaper to fix. A good exhaust and a custom chip, and a 3.2 will really scoot.
Rod bolts are only an issue if you raise the rev-limit.
2004 GT3
Old 08-10-2005, 04:36 PM
BReyes's Avatar
Alusils and Nikasils are both good, and upon disassembly/inspection it is easy to tell which one is present. It just depends which P&C set was pulled off the shelf at the factory. Both are good (3.2 also comes with either).
Bernard
Old 09-01-2005, 09:08 AM
KobaltBlau's Avatar
Are you sure, Tyson? My info says US 3.2s could be either Nikasil or Alusil, but all of the euro 3.2s were nikasil.
Andy
Old 09-01-2005, 11:32 AM
Irrationally exuberant
ChrisBennet's Avatar
My gut feeling is that the 3.2's they either had Niikasil Mahles or Alusil Kobleschmidt (sp?) P&C
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-01-2005, 12:54 PM
1972_911T's Avatar
Waynes book does list both nikasil and alusil for the 3.2's in the tolerence section at the back.
Old 09-01-2005, 01:08 PM
