2.4t MFI to 2.7 Big Bore?'s
I want what everybody whats more HP,
But I really like the way the MFI runs,
SO I was thinking of a Big Bore kit
I found one from Mototr Mister
911 2.4 1972-1973 to
2.7 Big Bore $1995.00
1. Has anyone do this before, is so what was done?
2. Is this kit something that he ships to you and you install?
3. Are there other kits like it out there?
4. What does the kit include , or do for the engine?
I don't think I have (or what )to use Motor Mister, I just what to get more displacement, If there are any other kits, or just list what I need to make it larger.
Derek
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 08-13-2005, 10:52 PM
He also had this set up
911 2.4 1972-1973 to 2.5 Big Bore $1695.00
If this does not come with new cams, shouldn't I change them as well, to maybe "E"?
I what low end and speed, but I think I will be doing over 130 very often....or will I ?
2011 M3 4Door
Old 08-13-2005, 10:59 PM
beepbeep's Avatar
Motor Meister? That wonderfull shop with good reputation?
P.S. How do you plan to modify MFI so it injects more fuel to offset greater volume?
Thank you for your time,
Old 08-14-2005, 07:12 AM
I am not sure how yet, maybe look for "S" MFI
2011 M3 4Door
Old 08-14-2005, 09:27 AM
Licensed User
Shuie's Avatar
Derek, seriously stay away from Motor Meister.
S MFI and 2.7 RS MFI would be the same thing so that would work. Your case will have to be machined for th 90mm pistons if you want to go to a 2.7.
Old 08-14-2005, 10:13 AM
Derek,
This is a very nice upgrade. It's been done before on this forum. Lots of options as far as cams, ports and pistons. You need 2.7 Carrera RS pistons (or custom such as JE) if you want to stick to any of the 2.4 litre cams. The case needs to have the spigots enlarged for the bigger cylinders. Also need timecerts and in my opinion Dilavar studs. Lots of info on this in the forum and in Bruce Anderson's 911 performance handbook.
If you can find a set of 2.7 Carrera RS pistons and cylinders you can use all your old heads, cams, ports, etc. This would be a minimal expense method and you'd have a torque monster but not much power above 6200 RPM.
-Andy
Old 08-14-2005, 07:33 PM
Andy,
That sounds great, DO I have to get the block machined to 90mm still??
What is JE?
2011 M3 4Door
Old 08-14-2005, 08:16 PM
Yes you have to have the case machined for 90mm cylinders and have the timecerts/casesavers installed (Dilivar Studs also in my opinion, others disagree). JE is a brand of pistons. Engine Builders Supply sells them. Look in some magazines and books to find machine shops and parts retailers. Call them with questions on prices and turn around times.
I recommend Ted Robinson of German Precision for machine work and EBS (Engine Builders Supply) as well as Pelican for parts.
-Andy
Old 08-15-2005, 11:08 AM
