What are my choices? 2.4T
Ok , I would like to keep my MFI
but I would like some more HP
What are the choices out the
Big bore kits? ......So on
Oh ya, I dont want to spend a lot more than putting in a 3.2
Really I don't know what I am talking about here, I am just trying to understand what is out there to give me more Hp and if I should use it or just buy a 3.2 and put it in the car.
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 08-14-2005, 10:12 PM
Bill Verburg's Avatar
Rebuild to 2.7RS spec, it isn't going to be cheap
Bill Verburg
Old 08-15-2005, 05:23 AM
Grady Clay's Avatar
Derek,
There is no substitute for displacement.
2.7 is better than 2.4.
3.2 is better than 3.0.
And then you can get more for much more $.
If you have a 2.4 MFI, want to keep the MFI then 2.7 (or 2.8) is a logical choice. An advantage of the magnesium case is weight (or lack of it). The disadvantage is it isn’t as strong as the later aluminum cases. With the modern techniques that limitation can be overcome.
There are two other considerations when looking for more power – compression ratio and cams.
Compression ratio (CR) choice is almost 100% fuel dependent. The higher the CR higher fuel octane is required. Some who only drive <10K per year use 112 octane leaded race gasoline for 11.5:1 CR. For most the CR is limited by the fuel available at the pump. Twin plugs allows slightly higher CR with the same fuel.
The progression of cams somewhat trades off performance, fuel economy and drivability at low RPM for higher power at high RPM. This is the progression from CIS cams to T,E,S and on to race cams. Your MFI is eminently suitable for more aggressive cams than your T.
Along with more power comes the catch. You will need more cooling capacity. A substantial front oil cooler and a higher fan ratio usually suffice. Since you tend to go faster, you also need to stop – hence larger brakes. Since you tend to drive more aggressively, more suitable suspension is desirable. At some point tire size becomes an issue so you install flares and wider tires & wheels. At some point you are putting so much power through the transmission, it needs an oil cooler. On it goes.
This progression is known euphemistically as the “Slippery Slope.”
What to do?
If it were my choice I would recommend you opt for Mahle Nikasil 2.7 at about 10:1 CR. Have the MFI, heads and cams be to 911S specs. Current electronic twin ignition with knock sensing. Bring the crankcase up to current standards; shuffle pins, line bore, oil circuit mods, Turbo oil pump, large piston nozzles, clearance the case and cylinder spigots. It will need a higher ratio cooling fan and a substantial front oil cooler.
Otherwise I would add stiffer torsion bars, good serviceable shocks, lowered and cram as much tire & wheel under the stock fenders as possible.
There are several dozen significant “while you are there” projects that should be undertaken simultaneously on a 33 year old 911.
One thing to keep in mind is that a 911 isn’t just an engine, it is a well balanced system where things are sized appropriate to everything else.
This makes a stock appearing, very drivable and serviceable 911. With 200+ HP and good handling it is a fun “wolf in sheep’s clothing.” This is pretty expensive but much more and the slope gets very steep.
If I were building a 911 for myself I would tolerate a true lightweight – under 1800#. A lightweight to the extreme 2.8, 12+:1 CR. Not much more than SC flares. Single out OEM muffler.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-15-2005, 09:28 AM
Home of the Whopper
The cheapest and most bang for the buck is....
2.2 Pistons and E cams. Nothing else needs to be changed and you'll have a NICE street engine.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 08-15-2005, 10:25 AM
Grady,
THanks for the insight , like always you are full of info.
BK911-
Tell me more, DO I leave the 2.4 cycliders in place?
DO the 2.2 need o be S, E, T ?
And just a set of E cams right?
Are the rods the same?
THis sound like somwthing I can do
2011 M3 4Door
Old 08-15-2005, 11:55 AM
Home of the Whopper
Do a search. Several people have this engine, myself included. Basically, 2.2T pistons will have about the same CR as 2.4S pistons. Add half a point for 2.2E and another half a point for 2.2S. Plus the E and S pistons weigh less than the T's. It's a good idea to get the matching cylinders for the pistons, but the 2.2 and 2.4 jugs are the same. You'd have to mic everything to make sure they'll work together if you mix and match. You can keep your rods unless they need to be replaced. So your initial shopping list is:
2.2 p/c's
E mfi cams
engine gasket set
That's it unless you find anything out of spec or damaged.
And like I've stated, several people on this board have this engine. And I don't believe anybody regrets it!
Old 08-15-2005, 01:45 PM
dtw dtw is offline
GAFB
Yep, done a variation of this (relieved 2.2T pistons with flycut heads instead of 2.2E pistons, and Crane 288 cams instead of E cams) and I love it. I also ported intakes out to 34mm.
Several BMWs
Old 08-15-2005, 03:29 PM
Cool, That sound great,
I think I will start looking for that right away!
2011 M3 4Door
Old 08-15-2005, 05:29 PM
maddogxx's Avatar
Hey Bk911, I am currently taking a 2.4 E motor and have 2.2 S pistons and E cams will this combo still work with MFI or should I think about carbs?? Thanks in advance.
Old 08-16-2005, 09:27 AM
Home of the Whopper
Yea, I would go with carbs and sell me the E MFI. Just kidding, don't even think about switching to carbs.
Old 08-16-2005, 10:13 AM
I have a 73 2.4T that I zinged at Road Atlanta this past weekend. The 2 cylinder's compression is 90 psi compared to the 120psi of the others. There is also a leak coming out somewhere near #2. Anyone else had these issues?
Sorry to hijack the thread, but this looked like a good place to start!
Old 08-20-2005, 08:08 AM
