goldgunner's Avatar
Oil Tubes - Solid or Expandable?
On a total rebuild, what's the consensus on which type oil tubes would be best to use - the Solids or the Expandables?
The expandables come in a Pelican kit - all the needed tubes and rings...the solids are purchased seperately. That would seem to imply the rebuild should have the kit, but from the pictures I see of the rebuilds, most use the solids.
So, what's the preference and why? please.
thanks!
jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 09-07-2005, 07:39 PM
I used solids. One or make that 4 less joints to fail.
Kevin
'79 Coupe
Old 09-07-2005, 07:44 PM
Wo ist die Rennstrecke?
DonE's Avatar
Solid - why not? Even tho the expandables don't leak, why not go for the cleaner look?
Old 09-07-2005, 09:35 PM
walt's Avatar
Go solid. If they ever leak in the future they are easy enough to replace with expandables.
Walt
82SC 3.0
81SC 3.6
Old 09-08-2005, 02:53 AM
Friend of Warren
Used solids on my rebuild.
Kurt V
Old 09-08-2005, 06:01 AM
Irrationally exuberant
ChrisBennet's Avatar
Solid = lighter, cheaper, less chance of leaks. It's a no brainer.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-08-2005, 06:39 AM
Walt Fricke's Avatar
Porsche Crest
If I have them, I use solids for three (for the reasons given by others), and a collapsible for the one nearest the oil pump scavenge outlet fitting (nearest #3 cylinder). That way I can always get a wrench conveniently on the fitting and its attachment if something needs tightening or to be removed (like the oil line) between teardowns.
Walt Fricke
Old 09-08-2005, 10:28 AM
89red911's Avatar
I used soilds when I rebuilt my motor.
The book I have says there is no real advantage to either. It seems it is a matter of preferance.
I agree that the solids have less places to leak than the others.
Just a thought but your rebuild did come with new collapsible ones so if you dont want to buy soilds dont.
Shiny side up, Rubber side down, Its the fastest way around the track.
Old 09-09-2005, 05:43 AM
Now in 993 land ...
aigel's Avatar
The only disadvantage of the solids is the fact that you better not forget to install them before you slap the cam housings on. I was glad that my buddy had collapsible tubes when we did his top end.
My pal had bought some nice turned collapsible Al tubes. I think they are made by Weltmeister. The best looking part I have seen come from that company to date. They may be worth looking into ...
George
81 SC (sold)
Old 09-14-2005, 11:16 PM
