Drill sheet metal for crank pulley bolt access?
I'm putting the sheet metal on the engine and I'm wondering if people drill the pulley cover and rear sheet metal to allow for socket access to turn the crank? I realize that the muffler will probably be in the way when it's all together, but it seems like access to the pulley bolt would be a plus. Comments?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I did this on the last two rebuilds I did.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Irrationally exuberant
I never had any problem turning the motor over using the fan pulley. I'd think a 930 (because of it's low compression) would be even easier to turn over.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I drilled mine cause I had to remove the pulley. I also found that I had to drill the bumper for access to drill the mount. I am glad I did drill the mount cause I have used the hole a few times now. It is a biatch to turn my 930 with the fan pulley. I don't know why but it is.
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
