Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
would it work?
can i stuff a 66mm crank into a 78 3.0 sc case or is that reserved for the 930/52 case? i have a 78 sc 3.0 case to play with and would love to put that crank in it since i have FINALLY convinced dad to let me build him a motor along with getting a hybrid.
damn porsche, too many options
ryder
evil car nut, tyson im sorry i havent been out, the local law enforcement wasnt happy with my BAC so a couple more weeks of no driving, i got off on a deal. catch ya'll later.
p.s. if your in socal and love porsche hit up the peterson museum. friend of mine that has a bookstore in old town pasadena has a steve mcqueen exhibit going on. read, jerry seinfeld's #21 gulf porsche 917, motorcycles, gt40 chase car from le mans, ferrari's, jaguars, fords, all steve's fun stuff.
bust me a vine im out
74 911s neverending story. two feet and a jetta for now.
Old 10-05-2005, 10:02 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: would it work?
Originally posted by Porschekid962
can i stuff a 66mm crank into a 78 3.0 sc case or is that reserved for the 930/52 case? .......
Not in an 911SC case.
3.0 Carrera and the 3.0 Turbo not to mention the 2.8 and 3.0 RSR case are the only big alloy cases that you can put aproduction 66mm crank in.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-05-2005, 10:08 PM
Thank you Henry for that very quick response, what is it about the cases that allows the shorter throw crank to fit? Just curious and I think I will be calling soon about a pump. I spoke with you long long ago about something like this for a 3.0
Ryder, big ideas, not enough cash
Old 10-05-2005, 10:33 PM
Author of "101 Projects"
Wayne 962's Avatar
The flywheel ends are bigger on the later cranks, so there's a bigger hole (and flywheel seal) in the end of the case. You need a Euro Carrera case, or use a 962 crank with the later cases (short stroke crank with big flywheel end).
-Wayne
Old 10-06-2005, 02:25 AM
The difference is more than just the flywheel flange. The main bearings are also different. 60mm for the 9 bolt crank and 57 mm on the 6 bolt crank.
Henry Schmidt
Ph: 760-728-3062
Old 10-06-2005, 08:43 AM
