46mm Weber vs PMO dilemma
I'm trying to decide whether to put my vintage 46mm Webers on a 3.2 engine (with 10.5-1 J&E pistons and performance cams) I just bought which already has new 46mm PMOs (with 38mm venturis). Car is used just for track days.
1. Is the technology that much better in the PMOs?
2. What's the going price for used 46mm webers?
Old 10-12-2005, 08:13 AM
PMO's are SOOOOOO much better in every way.
Sell those Weber's to a Vintage racer who needs them for those venues.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-12-2005, 11:13 AM
Any idea what the going price range is?
Old 10-12-2005, 01:10 PM
Plavan's Avatar
I second Steve's post. PMO's are the only way to go. They were out of 46mm's a couple months ago. Maybe Steve has a set for you.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 10-12-2005, 03:33 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: 46mm Weber vs PMO dilemma
I guess I'm the only one who read your post. You already have new PMO's and you want to know if you should keep them or swap them for the Webers you also own.
Use the PMOs
Yes the technology is slightly better but more importantly the PMOs flow more air which makes them better suited for larger engines.
If your engine won't flow the air PMOs are no better than Webers, except they are new and with carburetors new is good.
As for the going rate: I would think that $1500 for a good set of 46 Webers is a fair price.
Good luck
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-12-2005, 04:00 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Steve's Reply was in accordance with reading the post. Chad must of overlooked the part that said he already had the PMO's. No big deal.
So you may not have been the only one to read the post, just the only one who said they could read.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 10-14-2005, 01:52 PM
Jeff Alton's Avatar
www.turn3autosport.com
Old 10-14-2005, 05:18 PM
I would be interested in the 46mm Webers. Send a PM. Thanks, --mike.
Old 10-17-2005, 12:01 PM
Am building a 911ST motor for my FIA car (66mm stroke 2.5 litre): to keep to our race series rules I need Webers & can't use PMO's (shame, I hear they are much better!)
Am interested in yr 46's & will buy if they are in good order - can you send a pic? I think $2k is right if they are ready to use...
Please email with pic if they are available.
regards from England .....
Peter Rutt // 1965 2litre 911 FIA App.K racer
Old 10-25-2005, 09:29 AM
