Rods for 9-bolt 66mm crankshaft?
Did Porsche ever make steel rods for their race 9-bolt 66mm crankshaft? I understand they normally used titanium rods for their race cars but I wonder if they ever tried steel ones as well.
TIA. |
I don't know if Porsche used steel rods on this crank or not. What difference does it make? Do you want to use steel rods? I would think that any 2 or 2.2 litre rods would work. I could be wrong about this as I don't know if these rods are compatable with 3 litre pistons.
-Andy
72 Carrera RS replica, Spec 911 racer |
Some of those cranks have a 2.4/2.7 liter rod journal, making a 2.0/2.2 rod useless. It also makes finding factory racing rods pretty difficult. The convenient way to solve this issue is to have custom rods made. If you do have one with 2/2.2 rod journals consider yourself lucky. Forgive me I as I have read into your question . I would suspect that all factory efforts with the crank had ti rods installed.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ Last edited by BURN-BROS; 10-23-2005 at 09:00 AM.. |
Try not, Do or Do not
If I had one of these odd ball cranks, I'd sell it to someone else, perhaps a friend. Young Skywalker, this is not the crank you want Yoda says while waving his hand past your face
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
LOL!
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
I'd not previously seen mention of Porsche building a 9 bolt 66mm crank. Shows how there is always something a guy doesn't know. What race engines did Porsche build these cranks for?
Walt Fricke |
Author of "101 Projects"
Henry, can you post the specs on the 962 crank? You mentioned that you had at least one at your shop (journals, etc.). This original post is a good eye-opener, I can't say I know what the journals are on the 66mm crank. I figured it was the same as the early cars, but now that I think about it, that doesn't make sense.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Here are some loose specs off of the one I picked up recently.
mains 60 mm dia. rod journal 53mm dia and approx 24.25 mm wide I always figured that the 66mm 9 bolts had the same journals as a 66mm 6 bolt. It would have made more sense since they had loads of race inventory from the 2.0/2.2.
