Friends of Warren
Help me design a sweet engine
My car was hit a couple of weeks ago and it will spend "some" time in the body-shop getting fixed....
No better time to fiddle a little with the engine. I am starting with a 1997 3.6 Varioram with Euro harness. The sheet is blank and budget is somewhat flexible... The engine will be used in a dual street/DE car. I am thinking: 3.8 conversion Ti valves and retainers mechanical lifters cams ??? no idea rods ??? do I need to replace? ITB Jenvey or TWM 3006 Injectors ??? EFI = Motec M600 I don't have any experience just a lot of reading on this board. I'd love for you guys to chime in and guide me. I would love to get 310-315 usable rwhp with a broad torque curve but with the thrills of a screamer behind my back. Am I out of my mind? thanks again |
Hi Matteo:
Sorry to hear of your accident, but the fact that YOU are OK is the best news,...... ![]() One has a LOT more flexibility with regard for throttle response, drivability, and camshaft choice when you use a tall butterfly, 6-throttle intake system with EFI. I'd suggest either a 3.6 or 3.8 with different cams (there are several good choices), Pauter rods, GT-3R oil pump, crossdrilled crank, solid lifters, our tall butterfly intake system and either DTA or MoTeC Engine Management. You'll need to make a decision about whether you want to use pump gasoline or not. It goes without saying that RS valves, better springs and Ti retainers are a prerequisite. You can see our intake system on this page; http://www.rennsportsystems.com/1-c.html about halfway down the page. Thats a 330 HP 3.4 race motor in a relatively mild state of tune (race gas only) and a 3.8 would do much better. Without question, your budget will determine what you do.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 11-09-2005 at 09:40 AM.. |
Nothing beats boost Matteo!!!
Brian Keith Smith |
Friends of Warren
Budget is flexible in the sense that I want to have things done properly. For example I'd rather spend a bit more for a proven EFI system but be sure than it works with no problems. What is the displacement increase return? I mean a 3.8 is 5.5% increase vs a 3.6. Say that I could get 330 hp at the crank with the 3.6... Will the 3.8 yield 346hp? Or is there a diminishing return? I am not set to have the most powerful n/a engine... I want it to be fun. |
Friends of Warren
Both kinds of engines have a totally different "feel" so the final choice depends on what you use the car for and what you like,...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Friends of Warren
I am set on a N/A engine right now... I'll leave FI for the next project
I like Steve's suggestions a lot.
if you are going to the expense of all the other stuff to make it rev happy, rods are a given. The nice thing about displacement is that it is advantageous through out the whole rev range. The downside of displacement is cost ~$4k last I looked. I need to do my trans first, then maybe another 3.8 or 4.0 along the lines you are thinking.
