Less brakes, more gas!
euro911sc's Avatar
Marking Torqued Nuts
I was thinking of using a perm metal marker to mark items I have torqued down. This is because I have kids and only get a few hours a week to work on putting the engine back together and am afraid I'll forget I torqued something or worse, think I did when I really didn't.
I am looking at the metal paint markers in the MSC catalog:
MSC Catalog Page: 2618
Should I be worried that this stuff will come off in the case and clog something vital?? Outside the case I'm not concerned.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-21-2005, 09:21 AM
You might check with the Aircraft Spruce catelog as in the aircraft industry they use a paint to mark the nuts and bolts that have been torqued. That way they also can inspect hardware and know if it has loosened during preflight and periodic inspections.
Old 11-22-2005, 09:33 AM
Just checked out your link. I think I would go with the Industrial Markers if you are worried about stuff coming off and clogging an oil passage way. The paint tends to glob on.
Old 11-22-2005, 09:38 AM
euro911sc's Avatar
Right, like a permenant marker. That way if it disolves then it wont clog anything. I bet a red sharpie would work just fine now that I think about it!
Thanks!
-michael
Michael
'13 Cayenne GTS
Old 11-22-2005, 07:01 PM
Super Moderator
cstreit's Avatar
I've used "anti-sabotage" stuff on external parts but I have no idea how it would react inside an engine... Permanent marker isn't on oily parts so that doesn't work (tried it). I use a yellow grease pencil. Temporary, harmless, does the job...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-22-2005, 07:17 PM
Irrationally exuberant
ChrisBennet's Avatar
I just use a yellow crayon. It's probably not the best solution.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-23-2005, 04:02 PM
Super Moderator
cstreit's Avatar
Chris that's totally simple and should work well at zero cost... Therefore we're all against that!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 11-23-2005, 04:22 PM
You know what a cheapass I am? A friend and I went in on a tire marking crayon and split it in half!
"Gee Mark, I'll never use a whole crayon. Go halfsies?"
-Chris
Old 11-23-2005, 04:29 PM
euro911sc's Avatar
I know, first hand, how cheap Sir Bennet is! He cleans his parts with brake clean over a rose bush so he can fertilize the bush while he's at it... no joke!
did that thing blum again this year??
-Michael
remote messin' wit 911's member
Michael
'13 Cayenne GTS
Old 11-23-2005, 06:00 PM
