SMC SMC is offline
Help my Dad?
Can someone in or near Santa Rosa help my Dad.
We are in the process of restoring a 1970 911T with a 2.2 and Zenith Carbs. We rebuilt the engine and carbs and have it all back in the car. We have tried to start the car a few times now with no luck (it acts like it wants to start but will not catch). We have check for spark, checked for fuel pressure
even, rechecked the valve adjustment. If there are any Porsche experts in his area we could use your
Help.
1988 911 Carrera
1970 911T
1972 911E Roller
Old 12-02-2005, 01:34 PM
I am a long way from California and don't have any suggestions but I do believe this will get better response on the tech board. Many more eyes over there and this certainly would qualify as a tech question as well.
Good Luck
Kevin
'79 Coupe
Old 12-02-2005, 01:55 PM
SMC SMC is offline
Thanks will do.
1988 911 Carrera
1970 911T
1972 911E Roller
Old 12-02-2005, 01:58 PM
SMC SMC is offline
Help my Dad.
Help.
1988 911 Carrera
1970 911T
1972 911E Roller
Old 12-02-2005, 01:59 PM
B D B D is offline
B D's Avatar
Is there fuel in the carbs, what about spark? Pull a plug is it wet?
At TDC is the rotor pointing to the little mark, check the timing?
68 911L
Old 12-02-2005, 02:02 PM
Yes, yes, yes, yes, and yes. I will pull the plugs one more time and check again.
Old 12-02-2005, 03:09 PM
B D B D is offline
B D's Avatar
What about the order of plug wires, double check they match the firing order?
1-6-2-4-3-5
Here is image which shows the layout of the cylinders.
68 911L
Old 12-02-2005, 03:37 PM
Don Plumley's Avatar
I'm nearby in Petaluma, but unfortunately can only offer words of encouragement.
Don Plumley
M235i
Old 12-02-2005, 03:48 PM
goat's Avatar
I am close by. don't know if I would be much help but if I can I will help.
I wil pm you my phone number.
Had the same car at one time.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 12-02-2005, 04:27 PM
You know what would be helpful is a photo or diagram of the
spark plug wires going into the distributer cap. We have checked and re-checked them. My only concern is that they seem to be in the reverse order of my 88 911, can this be right. I was under the impression they were the same firing order.
Old 12-02-2005, 04:48 PM
addictionMS's Avatar
same firing order but the distributor rotates the opposite direction in the 1988.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 12-02-2005, 05:09 PM
stevepaa's Avatar
I can't imagine this is a Porsche unique problem. Any good old mechanic should be able to help on this.
This has the 051 distributor? Timing and dwell set correctly? There is spark at the plug tips?
I never worked on Zeniths, but I presume they are like Solexes. Floats actually float in gasoline? Is there gas in the float chamber and to the right level? Did you check the carburettors off the car by blowing air down the venturis and get gas to flow? Does the accelerator pump put out the correct amount? Did you measure it?
steve
old rocket inguneer
Old 12-02-2005, 11:26 PM
Nine9six's Avatar
Seems to me that Jim may have identified your problem...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-03-2005, 08:55 AM
Irrationally exuberant
ChrisBennet's Avatar
Jim
I thought the SC's were the only "wierd ones" that turned counter clockwise. Learn sumptin' new every day I guess!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-03-2005, 09:28 AM
I thought the same thing Chris.
Old 12-03-2005, 09:37 AM
The wires are in the reverse order of my 88 911 so the wires on the 70 911 are correct, if so lets still trouble shoot.
Old 12-03-2005, 11:15 AM
jhora's Avatar
Do you have compression in the cylinders?
John
Old 12-03-2005, 11:37 AM
checking I will let you know.
Old 12-03-2005, 06:10 PM
