Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
resident samsquamch
I'm sure you're right, Chris, but I dunno. There is NOTHING there for me to scrape. When the case separated, there was also no material spider-webbing between the case halves...sort of like the way an old gasket let's go...part of it on one half and part on the other. Don 't get me worng, I still plan to clean the p!ss out of this thing.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
If you use Three Bond 1104 on the case, do you run a bead and spread it or just run a bead?
Doesn't want/need a 3.6L
Ralph |
Thanks for the pics Ralph. It looks like you don't have to use to much and that coat is thin. How long does it take for the 1104 for dry?
It looks like Threebond 1104 is the cheapest of the lot at about $6 per tube. It looks like that is what was used on my motor previously and what the machinist uses that working on it now uses. I think I am going to use the Dow 730 with the probably false thought that it might squeeze in around the seal areas better.
Another good thing about the 1104 in my experience is that it takes a bit longer to dry than the 574 and isn't as messy to work with. It just seems like you have to have to orchestrate the case mating ritual perfectly when using the 574 before it starts to harden and makes me feel like I have to rush which for me means a mistake is more likely to happen. We tried to time it so the case got mated before quitting time and had the night to cure before starting work on it again the following day. Ralph |
Cheers, Mike ![]() ![]()
Mike 97 993TT Arena Red - "Scarlett" |
That orange sealant looks like Loctite 574 or the Wurth equivalent (not RTV).
-Chris
Maybe someone else at the class can remember what he was using...its was something cheaper because the class engine will never be run and was being used just as an example. What he did say is the bead size was typical of what he used when applying the 730. Cheers, Mike
resident samsquamch
It's hard to tell from the pictures, but I think 574 is slightly more traslucent than what is being used. Boy that sure looks sloppy though!
I think what Jerry was trying to do is show the "route" that he takes with the bead, i.e. what areas to avoid and on what side of the studs to follow. It is a bit sloppy though...mabye its practice from all that quick rebuilds he had to do while on the race teams!
He was using the orange permatex high heat rtv material for demonstration purposes only. He said to use about 1/16th of an inch of the 730.
[QUOTE]Originally posted by helidoc
He was using the orange permatex high heat rtv material for demonstration purposes only. He said to use about 1/16th of an inch of the 730. [/QUOTE So I guess this bead was a little thicker?
