Thanks Brian. Your build was an inspiration for me even though I was shooting for a street-only car. I'm using a TechEdge 2A0 wideband with the Bosch 7057 sensor. I've still got a little cable problem with it so the signal is a little jumpy. That means it's good enough to monitor and set the VE table, but not good enough to autotune. I'm going to have to rewire the plugs to get it to settle down (WB02 and sensor is very steady in my other car so I'm almost positive it is the cable).
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) Last edited by mppickett; 04-29-2006 at 03:13 AM.. |
![]() And yes, I also have Chris Kirby of K&B Auto to help me out. 100% invaluable.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Did you buy the MegaSquirt II v 3.0 in a kit complete (with ignition and injection) or did you piece it together yourself? I am thinking of going the same direction. I am also thinking of Tec-3 system too. Thanks |
I bought it already assembled from Jerry at DIYAutoTune.com Great guy, nicely done kits and great service.
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
What should my budget be (excluding manifold cost) to do an EFI upgrade like your setup? |
For fueling only (not ignition) if you buy assembled units and already have a wide band O2 meter:
MSII - $410 Relay board - $90 cables - $100 Stimulator (helps in calibrating sensors) - $75 Throttle position sensor - $60 Oil/water temp sensor - $30 Air temp sensor - $30 misc wire, resistors, zip ties - $40 heat shrink - $15 tape - $8 fuel injectors - $350-$400 connectors $40 shipping $50 This assumes you're pretty handy with electronics and have the basic soldering equipment already. I'm probably forgetting something, but this would get you in the ballpark.
Hey Mike, since I bought the roller from Jason, do you want to send me that engine so the two could be re-united LOL.. Just kidding ,, it looks great!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Twin-plug EDIS6 (dual controllers, dual coils, single VR sensor) driven by the MegaSquirt II. I give a lot of details in this thread. I bought the EDIS parts and Magnecor wires from Brian at Boost Engineering. Figure between $350-$450 if you get used parts (EDIS) and new wires. Plugs depend on what you put in.
Arnljot 1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband 1989 928GT 1972 BMW 3.0S |
The Innovate LC-1 should work just fine. Here's a thread on the Megasquirt forum on setting it up.
