Head Work - Recomendations
I'm looking for good head work. I will need to get the heads on my 3.2 done soon. Anyone have good experiences that they want to share and what should I budget to get the job done? Does it make sense to twin plug and "plug" those holes in preparation for when I am ready to get the Electromotive system?
Thanks!!
Mark
1987 Carrera
2018 GMC Sierra Denali 2500 Duramax
2012 Harley Davidson FLHX Street Glide
Old 01-01-2006, 03:29 PM
Air Medal or two
afterburn 549's Avatar
The ans .Is Absolutely YES!!! and dont let anyone say no . Once double plugged you have options dwn the road.......and that cant hurt. Its cheap to do it while apart...so much complicated latter.
As far as head work....almost a religion here..I do my own others say bigger /smaller ports.....for MFI/ Turbo CIS and what knot.....you will have to sort that one out.....I am a firm believer smooth is better then on both ends for a lot of reasons.....(Please dont start a thread war on this pt guys..I know the arguments just stating what I like.....might not be for everyone.)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 01-01-2006, 06:18 PM
Wo ist die Rennstrecke?
DonE's Avatar
Depends on how much and what you will do with the car. If its a daily driver and 100% street driving, then add up the costs (machine work, plugs, wires, iginition system, etc) and make your decision. Chances are, dual plug for a street driver is not worth it.
If you are going to build a hot rod with high dome pistons, then its probably a good idea. If you are going to build a track car, then yes.
As for head work, probably the most important point is finding a machine shop that is successful (improving performance) with their headwork program. Tell them what you want to acheive and let them make the recommendation.
Old 01-01-2006, 06:52 PM
Loose nut bhind the wheel
Lots of good shops, in California. I use German Precision but there are others. It makes sense to do it while it is apart. Call Ted @ German Precision and discuss it with him.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 01-01-2006, 08:47 PM
I used German Precision for my recent rebuild and Ted is a really nice, helpful, and knowledgable guy.
Old 01-01-2006, 09:51 PM
I used EBS. Call Jon he will be more than happy to answer and advise on any question you have.
http://www.ebsracing.com/
Kevin
'79 Coupe
Old 01-02-2006, 04:27 AM
Irrationally exuberant
ChrisBennet's Avatar
(Anchor) Atlantic Enterprises right next door to you in NJ does all my heads. Excellent quality, very reasonable prices and quick turnaround. AA # is 856-589-5577
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-02-2006, 05:26 AM
safe's Avatar
Is it not a waste of money without raising the compression (NA engine)?
I don't see the point of doing the machine work now and then add the expensive stuff later??
Magnus
Old 01-02-2006, 06:27 AM
abit off center
cgarr's Avatar
As Safe said if its stock I understand there is no advantage to twin plug, Im going 98mm and 10:5 cr so I did twin plug, so if you raised your cr later everthing would have to come apart anyhow to do so, I would either do the whole enchilada now or dont waste your money on the xtra machining although it is easy to do, they just get a lot of money to do it.
______________________
Craig
G2Performance
Old 01-02-2006, 08:18 AM
BReyes's Avatar
Sounds like you are on the slippery slope!!!!
Enjoy
Regards,
Bernard
Old 01-02-2006, 10:01 AM
I thinks it's more than just compression. The amount of fuel entering the combustion chamber is the other big factor. The more fuel you can efficiently burn, the more power Compression just helps with this process. I just thought by having it done now, it will allow greater flexibility in the future (i.e PMO Carbs). I think the cost of the machine work is relatively inexpensive compared to all the ancillary ignition parts.
Man it's tough to make a Porsche engine any better than it comes from the factory. LOL
Mark
1987 Carrera
Old 01-02-2006, 10:19 AM
It didn't occur to me that you might want to have the heads modified. A 3.2 head is said to flow enough for 300hp in stock form. Unless you are trying to make lots of horsepower I would leave the ports alone.
If you ever need to get the car smogged you will find that going to a factory 3.6 is more cost effective than trying to convert upgrade a 3.2. (BTDT)
-Chris
Old 01-02-2006, 11:09 AM
3.2 head work
Mark, we can do what ever you need in house at JB Racing, twin plug,street or race valve jobs,clean up port work to full race,Flow bench work etc... we are in Central Fla. take a look at our web site if you like.
Mike Bruns JBRacing.com
Old 01-02-2006, 12:38 PM
Re: 3.2 head work
WOW! That's some shop! That engine on your dyno brings back some fond memory's of being around my NHRA friends. Thanks for the link.
Mark
1987 Carrera
Old 01-02-2006, 02:07 PM
Jeff Jagusch's Avatar
SUPERTEC
Give Henry a call at Supertec, he can help you out with the cylinder heads as well as any other engine issues.
Nice guy too! He has been VERY helpful with my engine projects!
http://www.supertecperformance.com/
Jeff
Old 01-02-2006, 03:25 PM
Super Moderator
cstreit's Avatar
Second that. I enjoyed working with Jon
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-02-2006, 04:22 PM
I hear MotorMeister are the best
Mark
1987 Carrera
Old 01-02-2006, 04:33 PM
abit off center
cgarr's Avatar
you
Craig
G2Performance
Old 01-02-2006, 04:40 PM
DonE's Avatar
Actually, the two most important components for twin plugging are compression and displacement. The higher the compression, the harder it is to light the fire. Also, the larger the volume to light, the more the benefit to have multiple spark sources. Then add an obstruction like high piston domes, low AFR's, timing, spark plug placement and so on, the argument for twin plug improves.
In any event, talk to an expert for their input on your application. I chose JB Racing because of their proven race program and their willingness to take the time to talk to me about my options.
I think you can really improve an earlier porsche motor if you plan it out carefully. There are quite a few things you can do economically to wake these motors up. At the same time, Chris B has good advice for big power.
Old 01-02-2006, 06:28 PM
anh911's Avatar
There's no reason to add more fuel unless you have more effective compression. That means either you increase the compression ratio or force induction via turbo or supercharger. For any given displacement/HP engine the amount of fuel required is known, you can't make more HP by adding more fuel only. If you do inrease ECR by some means then twin plug can be a plus. Beyond a certain CR (subject of many debates here) its a must. On Porsche motors, the theory is that it has to do with some inherent inefficiency regarding flame front/travel in the combustion chamber due mainly to the less than optimal spark plug location.
Chris is correct, the 3.2 heads flow plenty out of the box.
anh911
'94 Dakota - Meh
'98 Moto Guzzi - woo hoo
911; XJS; Islander 36; All Sold
'97 YZF1000RJ - Totaled (Not by me)
Old 01-02-2006, 06:45 PM
