Getting the cam nut off
Are there any tricks to getting the cam nut off? I have tried but I am just not strong enough. Is this something that takes 2 people?
Old 01-05-2006, 01:49 PM
Don ot is on quite with a high torque. The way I did it was to put a long lever on the cam holding tool and brace it against the floor. With that in place and holding itself you can then put the crow foot on using again a very long lever, I used 5 foot steel pole on the breaker bar.
Steady pressure and it will pop off with a loud bang. Using the levery and bracing it against the floor you can do it easily on your own.
Hope this helps.
Mark......
Old 01-05-2006, 01:55 PM
Irrationally exuberant
ChrisBennet's Avatar
Be careful not to break off one of those little chainbox studs. It helps to have 2 people (or an impact gun).
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-05-2006, 02:09 PM
Navin Johnson
TimT's Avatar
impact gun
'69 911 GT-5
'75 914 GT-3
and others
Old 01-05-2006, 02:14 PM
It's like butter with the impact wrench.
-Brian
Old 01-05-2006, 08:33 PM
Yohoho......braaaaapppppt ! Yup, impact gun worked for me. But I bet some bozo's actually use them to put the nut back on too! ;-)
Mike
97 993TT Arena Red - "Scarlett"
Old 01-05-2006, 09:21 PM
Now in 993 land ...
aigel's Avatar
Isnt' he asking about the nut? Fill me in, how do you put the impact gun on a pre 80 engine with the NUT, not the bolt? The nut requires two tools. A cam holder and a crow's foot. You can't put an impact on the crows foot because it would be off center. And don't tell me you want to put the impact on the cam holder!
My advice is long breaker bars, stop one of them against your engine stand and lever the other one downward with your body weight. If that doesn't work, two guys or gals may be necessary to get it done.
George
81 SC (sold)
Old 01-06-2006, 12:23 AM
George
You use a large socket. The inertia of the cam itself does most of the cam holding for you. If you are careful, the chain won't be pulled on very hard and if you are rebuilding the motor you aren't reusing the chains anyway.
-Chris
Old 01-06-2006, 03:47 AM
the impact gun has been my only solution....
Old 01-06-2006, 07:02 AM
Does it matter that the crows foot tool is off center?
Old 01-06-2006, 08:05 AM
I used a socket with a big slot cut in the side....impact gun on the socket and cam holding tool through the slot...best of both worlds.
"not an expert, but I play one on message boards"
Old 01-06-2006, 09:25 AM
Now in 993 land ...
aigel's Avatar
-Chris
Ouch. Are you reusing the cams? This doesn't sound good to me. I guess it is a matter of preference. I am a big impact fan, but I'd keep it away from my unlocked valvetrain.
George
81 SC (sold)
Old 01-06-2006, 09:56 AM
Now in 993 land ...
aigel's Avatar
It may not make a difference regarding where the force applies, however, I'd be afraid of the foot jumping off - you'll mess up your nuts...
George
81 SC (sold)
Old 01-06-2006, 09:58 AM
This is one of those threads where I wait for JW to reply.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-06-2006, 12:37 PM
dtw dtw is offline
GAFB
Impact wrench, on either the nut or the bolt. A quality impact wrench applied properly acts on the fastener only and will not transmit significant force to the cam, chain, or valvetrain. No worries.
Now, whacking away for long whiles with a Harbor Freight special, that's a bit sketchy...but I've done it on POS parts motors and it's not a big deal. Think about the forces acting on those chains during full throttle accel/decel runs...
Several BMWs
Old 01-06-2006, 04:53 PM
