camgrinder's Avatar
The program I use is similar to this one:
http://kb-silvolite.com/calc.php?action=comp2
To find the intake closing point, take the duration at .050" and divide by 2. This number is added to the intake centerline. Then you subtract 180 from this number and you have the intake closing point at .050". The Silvolite program says to add 15 degrees, with a 911 cam 20 degrees is a better number.
Example is an SC cam
228/2=114, 114+113= 227 , 227 - 180 = 47.
47 degrees abdc is the intake closing point at .050", then add 20 degrees and the advertised closing point on the intake valve is 67 degrees.
John Dougherty
Dougherty Racing Cams
Old 01-14-2006, 01:24 PM
Try not, Do or Do not
Henry Schmidt's Avatar
1976 3.0 934 Turbo was CIS engine.
Was it easy to drive? Hell no, it was an absolute terror.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-14-2006, 01:52 PM
camgrinder's Avatar
Did the 934 run 1.4 bar?
How much boost could that engine in factory trim take?
John Dougherty
Old 01-14-2006, 01:59 PM
Send a message via AIM to air-cool-me
thanks john,
I came up with a dynamic of 6.310 vs a factory 6.12 with 8-1 with SC cams.. that sound right?
what is indicated by this?
SWB
Old 01-14-2006, 02:05 PM
Betwwen to 1.2-1.4 bar if I remember correctly.
Henry Schmidt
Ph: 760-728-3062
Old 01-14-2006, 02:10 PM
camgrinder's Avatar
Slightly higher cylinder pressure. The cranking compression will be higher than factory. Percentage wise the increase in minimal, but with the better breathing camshafts the VE is also increased.
John Dougherty
Old 01-14-2006, 03:04 PM
BReyes's Avatar
Originally posted by herman maire
Thats great info.
Im still pretty new to the Flat-6 motor and its limits , but with other motors it really comes down to Air/Fuel ratio's and spark timing to have a reliable high HP High compression turbo motor.
Corect me if I am wrong, but dont nascars use Carbs and fixed timing??
I think that would put them at a huge disadvantage VS a EMS system where you almost have infinte adj, low and top end. When I will adjusting my EMS on my motor I will be adj the Air/Fuel ratio's and spark timing every 100RPM if not more.
I think not many people are familiar with EMS systems and how incredible they are for engine tuning and for reliabilty.
Heres a quote from Corky Bell-
"Aftermarket EMS systems indeed offers the opportunity to create the 1000HP daily commuter automobile . The singular aspect of EMS that permits this is its fine degree of tuning available over huge intake manifold pressure ranges. By comparison, the finest carb in the world has four fuel- flow circuits that can be tuned over the range in which it is asked to operate. Over this same range EMS offers literally hundreds of fuel flow circuits- one virtually every hundred- rpm band and every inch of manifold pressure. Its equivalent to having 500 MAIN JET CIRCUITS IN A CARB" ect....ect..
Im pretty sure if that nascar car had a EMS system to run its 18:1 compression it would be interesting to see the results.
Again I am not a pro on p-cars far from it, I just really believe in 21st century electronics. Its pretty incredible what we have available to us.
Im temted to go with 8.5 and even considerin 9.0, 9.5.
I will see first hand if the motor nukes or pings with 9.0, 9.5.
I guess I like to learn the hard way. Even though it might destroy my bank account.
Oh and I feel the porsche turbo piston rings are not as strong as they should be( to thin they need to be thicker) so another week point to address.
I've spoken with a racer who ran 9.5 CO with 1.5 bar. Yes it was fast- and sounded very nice- safe for the dead silence of DNF.
So yes you can. Will it let go, of course. But if you are serious, you will find EMS, EFI, twin plug, exhaust, plus machine work, parts, and expert labor capacity, if you are ready, and can wait from few weeks to several months. And, there are a few turbo motors on the market right now that have all/most of the right components to do what you are going to do, AND MORE .
Regards,
Bernard
Old 01-15-2006, 07:38 AM
Wo ist die Rennstrecke?
DonE's Avatar
Originally posted by hobieboy
Don, what CR are you running with your setup? I think you have 3.4 Nikasil cylinder with JE pistons?
I have 8.0:1 JE Pistons and JB Racing cylinders. I also mitigate against detonation by conservative iginition tuning, 11.5:1 AFR (on boost) and very large IC (1 bar max boost).
In addition, it was my intent to have a car that has good all around drivability rather than high HP. If I was going to have a track car running >6000 rpm continuously, then I would have opted for the low CR pistons.
No doubt the Porsche engineers win every time, however I have a slightly different application and have tuned with pump gas.
Old 01-15-2006, 03:36 PM
mppickett's Avatar
Good info, Don. Just curious, have you dyno'ed yet?
Mike
Old 01-15-2006, 08:41 PM
adomakin's Avatar
Mike, I think Don is making about 500 horses
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 01-15-2006, 11:28 PM
Thanks to all for the great info...
John, based on the program you refer to, it sounds like SC cam/8.0:1 CR will result in similar dynamic CR as factory set up, so should work quite reliably even if other parameters (boost, ignition, etc.) are kept the same?
Don, that is my dilemma. The car is used really only on track and even with CIS and AFR of 12:1, I don't run more than .9 bar boost. In going EFI, twin plug/bigger intercooler, I'm debating if I can run "higher than norm" CR (8.0:1) and still have the headroom to go up to 1.0 bar boost if need be without blowing things up.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 01-16-2006, 06:41 AM
camgrinder's Avatar
If you have the same boost with the SC cams that you had with the stock turbo cams, you will be making more HP. This means the VE is higher and so is the cylinder pressure. The predicted dynamic compression ratio will be close to stock until the engine comes on boost.
You might have to pull some timing out of it. You should also run the highest octane fuel available. I wouldnt tell a customer in California with our crappy 91 octane fuel to try 8-1 CR/SC cams in a turbo unless he upgrades the intercooler or twin plugs etc.
John Dougherty
Old 01-16-2006, 11:15 PM
jadeblaquiere's Avatar
Send a message via Yahoo to jadeblaquiere
I'm somewhat surprised to see this is the first real mention of the intercooler in this thread... I would have expected intake charge temperature to be the primary concern.
Although "In theory there is no difference between theory and practice. But, in practice, there is", it's so much easier to theorize . From a completely theoretical perspective, here's what I would expect to face:
1. compression-induced detonation : the intake charge is just too hot : this is where the intercooler helps
2. hotspot induced detonation : combustion chamber surfaces too hot in points, too much fuel, not enough cooling air : this is where better cooling technology (e.g. nickies, polishing chamber) helps (does overdriving the cooling fan help?)
3. optimal fuel, timing : getting the right AFR, spark : engine management, right?
4. flame propagation : getting even pressure : twin-plugging
5. pressure : not blowing the head off the cylinder : grooves and rings
Am I way off base?
What the the practical pitfalls?
I have to admit I have no practical experience with overboosting a 930 engine (maybe if I park my 951 very close to my 911S under the full moon some magic will occur...) but plenty of people crank the boost on their 930 up to 1bar, why is increasing static compression significantly different?
Joe
Old 01-17-2006, 07:23 PM
camgrinder's Avatar
The intercooler is a big factor. Its amazing the difference changing the intercooler will make. I saw a rear wheel dyno sheet from a Ford Mustang, he had a water to air intercooler, 347 cu in and EFI and printed 2100 hp. I think the car has run in the 6's in the 1/4 mile.
John Dougherty
Old 01-17-2006, 09:57 PM
In my mind, its down to controlling heat, and fuel/ignition plays a big part in this.
As Henry asked, why didn't Porsche used higher CR in 934/935 - my guess is because of the non-precise CIS that was used? And both cars ran at 1.2-1.4 bar (yes with a complete engine rebuild after each race).
My question should probably be: if everything else is static, will 8.0CR at say .8 bar generates as much heat as 7.5CR at 1 bar boost?
I'm adding EFI, full bar intercooler, twin plug and ported head. My assumption is that I can control fuel/ignition needs and lowers intake temp as much as I can, so that I can at least reliably run the seemingly standard setup of 7.5CR with 1 bar boost using SC/964 cams.
Old 01-18-2006, 04:42 AM
DonE's Avatar
If I were building a turbo track car, I would use a 6.5 or 7.0:1 CR piston and use the cam to deliver power. John can make a custom grind for you that will give you the best VE in the RPM range you will use. At high RPM, there is no need for high compression on an air cooled, turbo motor with correct VE.
Mike - around 500 rwhp at 1 bar.
Old 01-18-2006, 09:00 AM
David's Avatar
How would one go about getting over 8:1 compression? Custom pistons? Weld up the head and remachine?
My engine's already built with 7.7:1 compression using 98mm JE pistons. So I'm not looking to change, just curious.
Old 01-18-2006, 12:04 PM
DonE's Avatar
The PO of my car shaved the heads to get .5 more CR.
Old 01-18-2006, 05:51 PM
Interesting question... I couldn't resist plugging it into a thermo model... so I dusted off something I used on a previous project (see: Engine Model Spreadsheet ) and here's the numbers I came up with:
Code:
CR	7.0:1		7.5:1		8.5:1		8.5:1
boost	0.75		1.0		0.85		0.9		bar
disp	3.298811773	3.298811773	3.298811773	3.298811773	L
power	355.0540054	423.9130639	411.7733869	423.5918055	HP
torque	339.142523	404.9157139	393.3200675	404.6088524	ft.lbs.
fuel	0.623223225	0.702155713	0.639227491	0.656078177	gal/min
T(comp)	341.3933003	369.7567893	395.8541554	398.2003086	C
Which would imply that in fact you would expect ~25C greater temp at the end of the compression stroke with 8.5/0.85 versus 7.5/1.0. In order to get the equivalent power you would need about 0.9 bar and you would be somewhere around 30C hotter. The only way the 8.5CR wins is in fuel efficiency. It should use about 10% less fuel for the same HP.
Of course this assumes you trust my thermodynamics. I'd be very interested to hear of practical experience to compare to the model...
Joe
Old 01-18-2006, 08:37 PM
3 restos WIP = psycho
kenikh's Avatar
Great old thread, bumped to the top.
There are some new(er) variables that need to be considered here. Given the ability of a progressive, ECU controlled methanol injection system to functionally boost premium fuel's octane to ~108 at full blast, the ability to blow water mist into the post-IC airstream (also sensor controlled) to further cool the intake charge, and J&S now having perfected their per-cylinder knock retard for the 911/930, my guess is that the old "max" numbers, even for a full-tilt, twin plug EFI don't apply.
Is it unreasonable to expect 1.2 bar from a 9.5:1 static CR, twin plug, big IC, full option EFI motor w/ knock control and all of the above bits? Maybe. This does result in an (at rest, boost corrected) dynamic CR of 16.3:1.
That said, those little watercooled Mitsubishi Evos, running the same spec engine control (EFI/knock control/big FMIC/H2O&meth injection) as above are regularly running near 30 pounds (2 BAR!!!) of boost at 9.5:1 static CR, and pumping a streetable, reliable, 650HP from a 2 liter fourbanger. Discounting the advantage of water cooling, 1.2 BAR (maybe even 1.5 BAR) seem downright accessible to an air-cooled motor if properly designed and managed. If that motor is a turbo 2.2 liter (with much smaller pistons than any production Porsche turbo), it seems even more likely.
That much boost might blow the heads off of a 911, ripping those Supertec head studs right out of their case savers, but the question begs to be answered.
Is this crazy talk or are we just taking convention for granted in light of refined technology?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-22-2009, 06:22 PM
