Ken911's Avatar
Angry best way to remove exhaust studs?
getting to the reassembly part of my 3.3 turbo motor . About half of the exhaust studs were broken off where the nuts are seated. They all are sticking out about an inch or so. I got new studs today and tried to remove a couple of them by cranking on them with a pair of vise grips. no luck one of them actually started to twist (not unscrew) so I stopped. they are soaking overnight with penetrating oil. any other suggestions from someone who has removed a lot of these?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 01-14-2006, 07:02 PM
Wer bremst verliert
JohnJL's Avatar
Try heating up the heads around the studs with ace, hit the stud with freeze spray and crank them out with the vice grips or snap-on tool ideally.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-14-2006, 07:21 PM
89turbocabmike's Avatar
Ken, these are tough to get out in one peice. I hope you luck out with penetrating oil. As John mentioned, an acetalyene torch is your best bet. I haven't tried the freeze thing, but use a snap-on stud remover and impact wrench. An impact wrench's action seems to work much better than a breaker bar in my experience. If it breaks you need one of these tools from fellow pelican "A Quiet Boom" see this thread for more info:
Does anyone sell a fixture for drilling broken exhaust studs
Old 01-14-2006, 09:48 PM
Ken,
I just removed 6 broken head studs in similar condition on a 3.0 with the devilar studs. I used an acetyline torch to heat up and found a set of stud removers at sears that worked pretty well and was able to remove all 6 without much of a battle.
Mike
1974 911coupe
Old 01-15-2006, 03:14 PM
Irrationally exuberant
ChrisBennet's Avatar
Originally posted by mikey911
Ken,
Mike
1974 911coupe
Removing head studs is a lot easier than removing exhaust studs.
The exhaust studs often need to be drilled out.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-15-2006, 04:04 PM
Ken911's Avatar
well made some progress about half of them have broken off flush and will have to be drilled out. one of the heads had time serts in it and those studs came out easily, so when i get all of them drilled out i'll install time serts so that in the future they will come out easily.
2019 Silverado 6.2L
Old 01-15-2006, 05:47 PM
I'd also recommend the high-temp copper anti-seize and copper nuts as added safety nets
Old 01-15-2006, 08:04 PM
Ken911's Avatar
no i have the silver anti sieze loctite N-5000 we use it where i work the copper stuff will stick so several years ago we switched to n-5000 or also n7000
2019 Silverado 6.2L
Old 01-16-2006, 02:14 PM
kind of a long thread, but christian, aka "a quiet boom", makes the tool you need.
206 637 4071
Old 01-16-2006, 08:14 PM
Ken911's Avatar
I know, I e mailed him this weekend. been having some trouble finding the time serts though the ones every one sells in the kit are too short. They make the correct size but all the distributors sell the short ones not the longer ones that are the same depth as the threads in the head.
2019 Silverado 6.2L
Old 01-17-2006, 05:58 AM
you usually don't need timeserts with this tool. google timeserts for a supplier. here, i did it for you. http://www.threadkits.com/timeserts/timeserts.html
206 637 4071
Old 01-17-2006, 08:05 AM
safe's Avatar
anti-seize?
If using anti-seize on aluminum parts, such as a head, an aluminum based anti-seize would be better right, or doesn't it matter?
Magnus
Old 01-17-2006, 08:16 AM
why do they need to come out easily? i'd rather they stay in.
206 637 4071
Old 01-17-2006, 08:30 AM
safe's Avatar
True, chances are you will not have to remove the again anyway.
My question was more general. I have seen recommendations to use aluminum AS on lug nuts instead of copper if you have aluminum wheels. The reason to that should be that the copper would oxidize the aluminum faster.
Magnus
Old 01-17-2006, 08:55 AM
Ken911's Avatar
As far as getting them out easily I figure down the road when I put on headers, etc and break some of them off removing the heat exchangers I would like to be able to unscrew the studs and replace them instead of having to drill them out all over again
2019 Silverado 6.2L
Old 01-18-2006, 04:54 AM
Ken911's Avatar
Oh and John thanks for the link!!!
2019 Silverado 6.2L
Old 01-18-2006, 04:55 AM
clarelaw's Avatar
I had 9 broken on my 3.0 - I paid my machinist to pull them when he did the rest of my machine work.
1981 911SC - Targa
1981 Vanagon -
1996 Honda Accord (wife's car)
1973 914 1.7
Old 01-19-2006, 08:04 AM
peter915's Avatar
Send a message via AIM to peter915 Send a message via Yahoo to peter915
I've just had my heads reconditioned and this included new brass inserts for the exhaust studs.
The studs where totally stuck, with the nuts siezed also. I blew the nuts off with Oxy and machine shop took the studs out & did the inserts. See http://www.cylinderheadshop.co.uk they did the work.
Peter
1986 3.2 "Outlaw" C2 coupe
Old 01-22-2006, 11:09 AM
All this is costly stuff.
It is an everyday matter for a jobbing mechanic to get fasteners out with no fuss...or sub-let cost..
The answer is pateince and heat, in evry case.
If the nuts are solid to the stud, fine..decide if the stud needs to come out..if so, heat the std and the casting, and get lube into this join..Candle wax is bets of all..or use paraffin, or Plus gas etc..
But if the stud is Ok to reuse. just heat the nut..it will come off if treated gently and lubricated.
It should be very unusual to have to drill out etc..a sign of impatience..
Kind regards
Old 01-22-2006, 01:33 PM
porschezealot's Avatar
did you ever resolve this? if not, try welding a more 'defined' piece of metal onto the stud, then try removing the piece of metal with vice grips.
Old 01-26-2006, 11:01 PM
