Nasty Old Engine - Value?
I have a nasty rusty old engine that I would like to get out of my garage. I can't find any serial numbers on it near the fan mount, but I'm pretty sure it's an early aluminum case 2.0. I measured on of the bores and it's 80 mm. Is there any value in this motor? I was thinking of trying to get $150 for it, but I don't even know if it's worth that. The pistons are rusted solid and I expect that only the aluminum case is salvagable, but you all would know better than me.
Thanks for any advice you can share.
Old 01-17-2006, 06:38 PM
Alan Cottrill's Avatar
it's probably worth a little more than $150. those early aluminum cases are somewhat coveted in the vintage racing circles. the drawback to your particular engine is that the case is the only thing of any real value and until it's tore down and inspected the value is questionable.
that said...I'll give you $150 for it...
big AL
'77 911
Old 01-17-2006, 06:43 PM
Found a number: 6404743 with a star on either side. I'm going to try and pull it apart. The cylinders are frozen solid.
Old 01-17-2006, 07:27 PM
914-6 2.0 basically 911T engine
Old 01-17-2006, 10:00 PM
Crusty Conservative
silverc4s's Avatar
That would make it a Mag case, right? Non counterweighted crank, etc... not very desireable at all.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 01-18-2006, 05:41 AM
So being that it is a mag case 914-6 motor, does it have any value?
Old 01-19-2006, 12:36 AM
3 restos WIP = psycho
kenikh's Avatar
YES; 914-6 cases are highly desired in the 914-6 community. Too many early mag cases were replaced with 911 cases after failures or when the motors got swapped out for more displacement. 914-6 restorers will pay a premium for a 914-6 case with a 914-6 serial number. Tear it apart, clean it up and sell it. Worth plenty more than $150.
Look here for reference: 914-6 case sales threads...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-19-2006, 09:46 AM
