Valve clearance question
I'm planning to run Solex cams on my 2.7L using the Mahle 8.5:1 Euro Pistons.
Has anyone done this? Does anyone know if I will have clearance issues?
Thanks, Bill
Old 02-01-2006, 01:24 PM
Try not, Do or Do not
Henry Schmidt's Avatar
That is one of my favorate engine for a 914-6.
I build my 6 that way 8 years ago. My 6 used carbs but we've also built the engine with MFI and the customers couldn't be happies.
Get street performance and a real kick to drive on mountain roads.
Do It Yourself Or Pay A Pro?
Supertec project finished
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-01-2006, 07:19 PM
Thanks for the reply Henry. My engine is almost the same except I used 2.7 "S" heads and just left the ports at 35 rather than opening them up to 36.
I'm planning to run a set of 40mm Weber IDA carbs on this. Any suggestion on Venturis and Jets?
This is for my 914/6 conversion.
Old 02-01-2006, 10:50 PM
