mudman's Avatar
T CIS Heads with EFI?
Is it acceptable to modify the injector bung in my heads (2.4 CIS)to receive pulse injectors or should I just have the bungs plugged/welded?
-Jeremy
'73 911 and other cool stuff
Old 02-08-2006, 03:59 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The heads get too hot to allow for proper injector function.
Weld/plug the hole and install the injectors away from the heat preferably in something that is insulated from the heat.
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-09-2006, 05:20 AM
mudman's Avatar
Thanks Henry! If I'm staying around the same displacement (looking at your upsize P/C) are the stock valve sizes ok or should I go bigger/smaller? Aside from normal r+r stuff is there anything else to do to these heads to prep for EFI?
-Jeremy
Old 02-09-2006, 07:09 AM
