Casesavers
Can someone please enlighten me re Casesavers? In the UK we are familiar with Helicoils (probably like the time certs mentioned on the Pelican site) but I have not come across Case Savers.
What is involved in installing them?
Is it a DIY job or one for the machinist?
Is any special tooling or equipment required to install them?
If so how much $$$$?
Hope to hear soon - my 2.7l is in complete strip down and I need to have it ready to rally after Xmas
Paul
Old 10-24-2008, 02:49 PM
abit off center
cgarr's Avatar
A casesaver is a steel threaded insert, OD is 14X2mm Its really not a DIY job unless you have a mill, I set the case up on my Bridgeport and use an end mill to cut the new hole then use the mill to cut the new thread, I made an install tool which is nothing but a socket screw as you can see, a little loctite and run them in. The mill is used to keep them straight and accurate. I get $175 to do a case, I don't know what others get? I also install a casesaver in the 8mm thru bolt at the lay shaft.
______________________
Craig
G2Performance
Old 10-24-2008, 03:24 PM
Irrationally exuberant
ChrisBennet's Avatar
How does a case saver differ from a Timesert? Is is thicker?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-24-2008, 06:15 PM
abit off center
cgarr's Avatar
I have never used timeserts but I think it was posted here that the threads are finer so you don't get the bite like the casesavers.
Craig
G2Performance
Old 10-24-2008, 06:36 PM
