Multiple cylinder base gaskets ???
Here's the background - I'm not sure how thick I need for the base gaskets as I'm using a different set of cylinders that happened to have been shaved.
If I ended up needing say .75mm, would it be ok to use a .5mm + a .25mm or should I go out of the way (e.g. not getting it from our host) to find a .75mm (or worst yet 1mm) gasket?
thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 02-18-2006, 04:54 PM
Jeff Alton's Avatar
You can stack, I have stacked two a couple of times with no leaks at all. I think Henry has them in the different thicknesses though.
Cheers
www.turn3autosport.com
Old 02-18-2006, 05:26 PM
Thanks for the confirmation Jeff - that's what I thought as well.
Now, I need to pre-assemble & measure the clearance. Once the gaskets are squished once, are they re-usable? My thinking is: if I start with, say, 2 .25mm ones, and end up needing 3. Can the 2 be re-used?
thanks.
Old 02-20-2006, 06:59 AM
adomakin's Avatar
ive stacked mine. i think the general consensus is that its ok if you dont go mad
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 02-23-2006, 12:21 PM
Irrationally exuberant
ChrisBennet's Avatar
Competition Engineering also sells thicker base gaskets.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-23-2006, 03:23 PM
stevepaa's Avatar
I would just go with the correct height single gasket after you figure out what that height should be.
good luck
You might also check with Jerry Woods. They made a single for each side for me.
steve
old rocket inguneer
Old 02-23-2006, 03:52 PM
Thanks for the input guys...
I'm doing some pre-calculation prior to assembly, so hopefully the clearance will be ok that I don't have to dismantle the p&c.
I have also been told from a few experience builders that stacking 2 is ok, so will probably leave it at that if I only need 2. But will likely get a thicker 1 if I end up needing 3.
Old 02-23-2006, 04:07 PM
No Expert
jgparker's Avatar
I asked a similar question a while ago and got some good info in response. Here is the thread:
Cylinder base shim, how thick is too thick
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 02-24-2006, 04:30 PM
