-   -   Another 3.6->3.8 Rebuild Thread... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267356-another-3-6-3-8-rebuild-thread.html)
Candelaria 05-27-2007 11:28 AM
Any updates on the outcome of this rebuilt???I like how you this this,very methodical!!!
CBRacerX 05-28-2007 07:54 AM
Been driving the car around regularly, did another oil change (still Dyno for now) and getting ready to swap out the stock v-ram chip for the RS version. Runs great!
Candelaria 06-14-2007 07:37 PM
Did you took care of the oil leaks??
CBRacerX 06-14-2007 07:43 PM
Nope, not yet - I figure there are plently of cold and wet months for me to do that :)
Candelaria 06-14-2007 08:01 PM
Well, that sucks!!
CBRacerX 06-15-2007 04:30 AM
Well, that sucks!!
Gee :rolleyes: - I guess it would be more fun to pull and re-seal the motor (which for me and my work/family life would be at _least_ a month) instead of driving every day with the windows and sunroof open and enjoying the 3.8 puuuush from back there....
Candelaria 06-15-2007 05:25 AM
Well, as long the oil is not dripping on a hot surface (eg. headers)it won't be that much of a pain!
kirkf 06-18-2007 07:02 PM
My car is still leaking at the thermostat housing. I went in once to fix it and I thought I had it all sealed up, and then it started leaking again. I havent gotten back to it again yet.
I am dropping the engine next week to start the supercharger install so I guess I will look at it then.
Kirk
YTNUKLR 01-25-2008 06:08 PM
My understanding is 3.8 pistons/cylinders drop onto a 3.6 case? Or does the case need to be bored?
Thanks,
Scott
cnavarro 01-25-2008 06:14 PM
There are slip-fit and machine in variants of the 102s; traditionally, then you can go to 104s at the larger 109 case register.
CBRacerX 01-26-2008 07:10 AM
Thanks,
Scott
In this case I used the machining required version, which is generally acknowleged to be stronger.
ianc 01-31-2008 08:02 PM
Great thread! Really enjoyed reading it.
A little vid or two might round it out nicely, don't you think?
ianc
CBRacerX 05-28-2009 01:54 PM
Status Update: Recently reinstalled this engine after tearing it down to seal the base of the cylinders with Threebond 1211, install a new flywheel seal and new case thru bolt o-rings. I went with the Wayne book approach of using a very small amount of sealer (1211 in my build) under the case thru bolt washers and nuts/bolt heads. Also installed a set of Imagine Auto lower valve covers. Pleased to report that there are no leaks!! Whew.
Also installed some software to try and get the engine running closer to potential - Steve Wong provided a baseline chip (3.8 RS I think) and I will be getting a dyno run done to complete a custom chip. But even the baseline chip is much better than the ROW V-Ram programming I was running (that I never really pushed hard).
wax105 05-29-2009 05:31 AM
Keep us posted on the dyno run Chris! Congrats...
0396 07-13-2014 01:35 PM
Congrats!
lbpa18 03-25-2020 06:29 PM
Ten years ago now. Looking back, was it worth it to go 3.8? I might be in line to do the same. Also, how many hours did you spend on this project DIY?
Thanks,
Lou
CBRacerX 03-25-2020 08:22 PM
Thanks,
Lou
It was a great build and I would do it again anytime. Engine ran great (I have since sold car). A full tear down and rebuild is about 90 hours of labor depending on the options pursued.
