Another 3.6->3.8 Rebuild Thread...
Here we go! Time to update the leaky cylinder to head sealing on my oil sieve of a '90 3.6 in the '87 with some RSR 3.8 P&C, 3.6 RS Cams, bigger intake valves, headwork, casework and new DME tuning on the Euro Varioram. This thread will document the work so others may comment on mistakes I am about to make, and keep the progress up front so I don't get lazy :)
Chris Today's work was extraction and basic strip. Total time 4 hours. Its out of the car... http://forums.pelicanparts.com/uploa...1140407178.jpg Get the G-50 off http://forums.pelicanparts.com/uploa...1140407201.jpg http://forums.pelicanparts.com/uploa...1140407218.jpg Attach to engine stand http://forums.pelicanparts.com/uploa...1140407265.jpg http://forums.pelicanparts.com/uploa...1140407293.jpg Strip to long block http://forums.pelicanparts.com/uploa...1140407314.jpg |
I'll be watching Chris. You're a brave man to be starting on such a cold weekend. I didn't see any heat in that garage either. I'd like to stop over sometime & check on your progress.
Ambient temperature 28 degrees F, no heat on yesterday. Those surgical gloves are nice and cozy though :)
Local area Pelicanites new (Like Larry - Welcome!) and old are invited to stop by and see the carnage. Chris |
Chris,
My dog watches me work in the garage just like yours are doing in the photo. You're going to be throwing a pile of $$ at that engine rebuild aren't ya. Good for you. I will be watching. Will you be doing some work on the G50 also? Have fun! Michel |
forget the 3.8 conversion unless you are going to go mad with the spec.
Buy Ninemeisters new 993 billet heads. They will see you on your way to 360bhp from 3.6L. |
Michel - Right now I plan to only freshen the syncro's on lower gears in the G-50, and check the condition of the Limited Slip
red964 - I will take a look at the heads from Ninemeisters, but I suspect they will be out of my budget (yes, there is a budget and it involves how I can make selling spares in ebay and the Pelican For Sale board). I got a set of 3.8 RSR Pistons and Barrels in 964 style at a reasonable price, hence the 3.8 upgrade... |
OK, the straigth dope from ninemeister on the heads is
"the 9m Heads on a 964 with Motec will also make gains, as they did on my race engine in taking it from 392 to 415bhp with no other modifications" And since I am already starting with the 964 heads, the gains from the billet heads do not make up for the very high cost. And this a street engine at the end of the day, so cams cannot be outrageous. |
Another afternoon
This time with warmer temps. At the end of the 3 hour spread, the long block was down to 2 studs, a cam housing and a stubborn front pulley (need to get or make a tool to remove this, and that is proving somewhat difficult). Most of the studs were not too bad, I used a Facom stud remover right on the threads (I am not saving these of course) although some mild case heating was required and the use of the pipe wrench was common~!
http://forums.pelicanparts.com/uploa...1141603375.jpg http://forums.pelicanparts.com/uploa...1141603404.jpg http://forums.pelicanparts.com/uploa...1141603436.jpg Here is what the heads look like fresh off the engine: http://forums.pelicanparts.com/uploa...1141603539.jpg http://forums.pelicanparts.com/uploa...1141603556.jpg |
The factory manual mentions that you should cover the rods where they stick out of the case with a bit of hose.
Otherwise the rods can bang up the spigot sealing surface. I used some clear hose from Home Despot. http://forums.pelicanparts.com/uploa...1141604594.jpg -Chris |
Thanks Chris, I have some of those and will be using them when I start rotating the engine again, that will be just before I try removing the front pulley :)
Chris |
Shameless Financing Plug...
I'm selling quite a few cool Porsche related items on ebay at the moment, to finance this rebuild. You might want to peek User cbracerx, what else :) Chris |
First, a big thanks for all the folks who bought items I had on ebay, this is a big help. I promise to spend it on the engine :)
Today I got a few tools from Baum, including the crank pulley removal tool. Got the pulley off (finally!) and pulled the right side cam housing and final two studs. So now I have this: http://forums.pelicanparts.com/uploa...1142627431.jpg So I am ready to split the case! Maybe sometime this weekend I will get a few hours... |
Chris, I need your phone number. I may be around New Hope this weekend. PM or E-mail me.
Some more progress
Yesterday the two year old took a two hour nap. I got the case split and took the rods off, did a rudimentary cleaning of the case. Also removed the heads from the cam towers. No bad surprises so far. I have some main bearing wear, and the nose bearing looks reusable at this point. Once the P&C appear in my mailbox I can get all these items to the machine shop and get the real work done.
http://forums.pelicanparts.com/uploa...1142784216.jpg http://forums.pelicanparts.com/uploa...1142784291.jpg http://forums.pelicanparts.com/uploa...1142784318.jpg http://forums.pelicanparts.com/uploa...1142784344.jpg |
Today's Nap :)
Pulled all the bearing shells and inspected. Got the case stud holes chased with a bottom tap (amazing amount of junk in there from loctite). Pulled the air deflection studs and chased all external threaded holes in case. Put the machine shop "packages" together (heads, rockers and shafts, rods, case and crank). All I need now are the P&C so I can kick off the next phase. While that is going on I will clean the remaining items and gather parts as needed. Inspection shows that the crank will benefit from being polished, so that is certainly getting done. I'll leave the potential (I think unlikely) for a line bore to the machine shop. Anyone care to decode the bearing part numbers? If I am right, this engine has never been apart before, so they should be std/std...
http://forums.pelicanparts.com/uploa...1142804571.jpg http://forums.pelicanparts.com/uploa...1142804592.jpg http://forums.pelicanparts.com/uploa...1142804618.jpg http://forums.pelicanparts.com/uploa...1142804642.jpg http://forums.pelicanparts.com/uploa...1142804679.jpg http://forums.pelicanparts.com/uploa...1142804701.jpg http://forums.pelicanparts.com/uploa...1142804714.jpg http://forums.pelicanparts.com/uploa...1142804744.jpg http://forums.pelicanparts.com/uploa...1142804772.jpg |
Very nice! Any time I see Porsche part numbers on the bearings, I typically think the engine has not been apart before, and yours looks like it has a date code. Is your motor a '91 with a VarioRam 993 intake?
Best, Scott |
Scott, my leaky motor is a '90 with a '98 vram intake, euro DME and 993 HE.
After this little "rebuild" is done it will be a street version of the 964 RSR engine, without the fancy individual throttle bodies. Chris |
First Disappointment
After a long wait, the 3.8 RSR Pistons, Cylinders and rings arrived. Pistons were all I was expecting (which is easy since they are new)! However, three of the cylinders have signficant scratches :( http://forums.pelicanparts.com/911-engine-rebuilding-forum/273486-used-cylinders-scratches-make-them-junk.html#post2487290 So I have contacted the seller and asked him to make amends. If he unwilling to replace them, then I suggested returning the cylinders and keeping the pistons. Does the use of Nikies instead of the factory part give anyone pause?
Chris http://forums.pelicanparts.com/uploa...1143328573.jpg http://forums.pelicanparts.com/uploa...1143328583.jpg http://forums.pelicanparts.com/uploa...1143328593.jpg http://forums.pelicanparts.com/uploa...1143328607.jpg http://forums.pelicanparts.com/uploa...1143328617.jpg http://forums.pelicanparts.com/uploa...1143328632.jpg http://forums.pelicanparts.com/uploa...1143328642.jpg |
To answer your question, those particular Nickies are set up at 102.00mm, which if I go by the 101.94 shown in the picture, would give you .0023" total p/c clearance, which is at the upper limit of the .0025" that I like to run; typically I set up a JE (which expands more btw) with .0015" total p/c clearance. Not to say that a set couldn't be plated and match honed.
Thanks Charles, I am also considering sending LN these cylinders and having them redone, what are your thoughts there?
Chris |
After some conversations with Charles and the comments from Henry, I have downgraded the apparent "damage" on some of these cylinders to be not so terrible. So now I will measure them and see if the Piston to Cylinder clearance is acceptable.
Charles provided this procedure that I plan to follow (thanks!!, posted with permission): Assuming you know the diameter of the pistons and they are all the same since they are new, here's the way I like to measure cylinders. You will need a table to collect measurements. I like using a digital precision dial bore gauge; I have one that reads in .0001" increments for this. You will want to orient the cylinder such that it is sitting how it would go on the engine. Picture 0 degrees as the top of the cylinder that points towards the heavens. Then also imagine a point 90 degrees clockwise from this point. You will be taking diameter measurements across the bore at 0 and 180, 90 and 270. To be even more thorough you can measure across at 45 and 225 degrees too. I then measure at .800" down from the top (top being the surface that mates with the head), 1/2 way down the bore (not including the skirt of the cylinder- head to deck length of the cylinder only), and at the start of the skirt (right around the point where the ledge that rests against the case is). You will want to take each measurement such that it is repeatable within .0001". No more than .001" of taper from top to bottom is allowed, as long as the bore remains in spec with regards to total piston to cylinder clearance. No more than .0005" of ovality at any given point within reason, although I do like them to have little or no ovality towards the top (that's why I measure at .800") where the rings will be doing most of their work. This is hard to nail down because it highly depends on who is doing the honing, the condition of the diamond stones, how many stones are used, honing pressure, etc. There is no such thing as a perfect bore. I have had customers searching for that perfect cylinder who go through the trouble of CMM'ing cylinders and it is possible, but it takes lots of time and $$$. Another good measure of how square the cylinder was after being remachined (if top deck and cylinder bases are parallel) would be to measure the head to deck length of the cylinder at the four corners (45, 135, 225, and 315 degrees). It's hard to say what is right or wrong other than we shoot for the no more .0002" difference between measurements, although I would guess that anything +/- .0005" is as good as new. Another measure is the perpendicularity of the bore to the decks, but this is almost impossible to measure statically. We have a special mandrel that centers on the bore across the entire length of the cylinder which we then can freely rotate the cylinder and use a dial gauge traveling across the top deck to do this measurement. Again, we aim for no more than .0002" difference but anything +/- .0005" is as good as new. All measurements should be taken at ambient 65 degrees give or take a degree or two and all measuring equipment should be at the same temperature. Measuring tools will change their readings as they get warmer, do be aware that if you hold your measuring tools too long it will change readings as much as .0005". The same can be said of the cylinder base that rests against the case, although this is harder to measure. Before taking any measurements I am careful to clean all tools and the cylinders thoroughly, and I lubricate the bores with a quick wipe of non-detergent 30 wt oil, but any oil will do. This takes me about an hour to do to a set of six cylinders, and I do it all the time. Be patient and i'm sure you'll be able to do it. Charles L Navarro LN Engineering http://www.lnengineering.com Aircooled Precision Performance |
The other thing I neglected to mention is the whole clearance subject. It's the bore minus the piston diameter gives you the total piston to cylinder clearance, since the subject was brought up on another thread.
If you have a used set of pistons and you are trying to re-use them with replated cylinders, short of match honing each bore with a piston that has already had it's skirts collapse, I like to find the largest diameter and set up the bore size based on that, as long as there isn't much more than .0005" of variance between pistons- you don't want one single cylinder to have excessive clearance or slap. Nice thing to note since most platers will not plate and match hone a re-plated cylinder to a used piston, so this is the way to get around that. |
Just a little advance warning that this thread will start to heat up again :)
Camgrinder has delivered my reground cams (Super C2), and reconditioned rockers and shafts (thanks!). I have the case, crank, rods and heads coming back from the machine shop this Friday. So I am now making the "big list" of everything else I need to purchase, from bearings to sealant to big hammers... PET is a big help, as is Waynes book for organization. But I do have a few questions... I know there is another engine gasket kit I can buy aside from OEM, and it has gotten good review here. But I cannot recall the manufacturer? EDIT: OK, I found that it is Wrightwood Racing :) I am using 3.8 (102mm) machine in Mahle cylinders. What should I be using for a sealing ring on top (Supertec Graphite or ???), and what is needed where the cylinder enters the case (larger o-ring or ???)? On the <3.6 engines it was standard to replace the cam chain ramps. Mine are now 16 years old, and made of plastic - so I guess they get replaced. How about the roll pins used to locate them? Is anyone using the optional rocker shaft seals? OK, that is enough of a grab back for now. Thanks everyone! |
There are many options for the sealing ring. You can first of all use the stock sealing ring on your cylinder (if it has one), or you can flame ring it. EBS Racing can supply sealing rings, as can Performance Developments, who can cut both the heads and cylinders for their interlocking sealing ring. Turbokraft (Chris Carroll) uses an interlocking ring that uses the stock diameter, but gets cut deeper into the cylinder and the heads. You might want to do a search on sealing rings to see what your options are.
As far as the case is concerned, you can o-ring the case. Charlie at Wrightwood Racing can supply the o-rings for when you groove the cylinder spigots in the case. Short of o-ringing the case, I'd just use a thin bead of Curil K-2 at the base of each cylinder. Actually now that I think about it, I would use the Curil either way. |
Machine Work Done - Whew!
I finally got the parts back from the machine shop today (Atlantic Enterprises EDIT: http://www.precisionheads.com ), and I am happy with the work done.
Crankshaft Polished Rods Reconditioned Heads Machined for sealing ring 102mm cylinders Valve Job with new exhaust valves and Camgrinder valve springs installed Case Machined for 102mm cylinders I now just have to do the final case checks (squirters) and cleaning, then start assembly. It is time to start making things happen! http://forums.pelicanparts.com/uploa...1149737416.jpg http://forums.pelicanparts.com/uploa...1149737444.jpg http://forums.pelicanparts.com/uploa...1149737466.jpg http://forums.pelicanparts.com/uploa...1149737498.jpg http://forums.pelicanparts.com/uploa...1149737514.jpg http://forums.pelicanparts.com/uploa...1149737541.jpg http://forums.pelicanparts.com/uploa...1149737559.jpg http://forums.pelicanparts.com/uploa...1149737575.jpg H'mm - did I forget anything? ... |
Great tread
I cant wait to see it all go back together. How much $$ did the machine shop work run you? I am looking for a good shop in the east and dont trust any around my area. |
Re: Machine Work Done - Whew!
The machine shop (http://www.precisionheads.com in Pitman, NJ) was $1700, and that included pulling two plugs in the oil cooler area, so I could install an oil filter housing in that location. Includes the new TRW Exhaust Valves.
Tell 'em Chris Brown referred you, I get a bag of candy for each new customer :) |
Sending Dist to Mark Cohen for a belt replacement (preventitive maintenance move)
Mark.A.Cohen@delta.com The history on this is unknown. It does have the belt vent kit, but this the perfect time to get it current. I am replacing the alternator brushes for the same reason. |
-Chris |
Still pluggin along...
Today the wife and kids went swimming - without me.
I got the case clean - really clean. It took a while, with razor blade, copper brush, heavy duty "paint prep" scotchbrite pad, dremel wire brush and lots and lots of brakekleen (bought the one gallon size). I also cleaned the oil pump up, it was dirty enough that after a partial cleaning it would no longer complete a 360 degree revolution since gunk was in the gears. That took a laquer thinner bath and movement of the pump, then a Brakekleen bath. Also cleaned up the intermediate shaft, and Wayne's book was right on, lots of gunk in the shaft after removing the plug. Cleaning the case sealing surfaces was time consuming, the machine shop had done a great first pass (in fact they cleaned the case twice), but it was not enough. I also confirmed the operation of the piston squirters, and cleaned the thru bolt passages. Cleaned the crankshaft as well, confirmed the oil passages are clear. Also cleaned up the cam towers and new chains. Then I assembled something! Got the bearings in the case and installed the Oil pump, chains and intermediate shaft. Checked the backlash. Wayne's book has this going in after the crank, but I checked the crank fit installing afterward and all is well. In the category of "while I was there", I replaced the alternator brushes and voltage regulator. Next: Crankshaft assembly awaits the new scale from UPS... http://forums.pelicanparts.com/uploa...1151895492.jpg http://forums.pelicanparts.com/uploa...1151895507.jpg http://forums.pelicanparts.com/uploa...1151895586.jpg |
I don't see the machined grove on the cyls. spigots, for oil sealing O ring, it will leak some if you don't do it., cheers, Ant.
I was under the impression that with the green viton O-rings and a little threebond 1211, a leak at the cylinder base was unlikely.
More of a race motor option. Kirk |
I am only going to use the Threebond 1211 on the cylinders, prior experience tell me this will not leak.
EDIT: No Base o-rings are planned to be used, and I may use Curil K-2 on the bases. |
As soon as you tight the cylinders down, the seals will split, they are to big for that small grove on the base of the cylinder, 1211 will do its job, but it will be a bandaid fix, if you have everything apart, why don't do it?, this happened to me once, on a 3.8 993TT, I did exactly what you are going to do, in a few months I was spliting the case, to do the RS seals., cheers, Ant.
Thanks for the details, I am not planning on using the o-rings at all. I agree with you that putting them on without the machining is a mistake.
Cheers, |
Chris
fantastic thread. I am looking fwd to the updates. |
(Re-written in abrreviated fashion after failure to post - arrghh!)
After getting my scale in house, I took a few hours today to weigh the rods, wrist pins, pistons, rod bearings and rod bolts. I didn't consider the wrist pin clips - so sue me :) I was lucky that I had just the right combinations of heavy piston and light rod and light piston/heavy rod to get everything to exactly the same weight without doing any machining of the parts (whew!). Weighing piston w/o pin (417 grams) http://forums.pelicanparts.com/uploa...1152419259.jpg Weights and matching components (I got lucky!) http://forums.pelicanparts.com/uploa...1152419268.jpg Rods with old bolts removed and surgical cleaning! http://forums.pelicanparts.com/uploa...1152419281.jpg Last check of wrist pin fit http://forums.pelicanparts.com/uploa...1152419292.jpg All parts ready for assembly http://forums.pelicanparts.com/uploa...1152419311.jpg |
Get unstretched measurement of each ARP rod bolt
http://forums.pelicanparts.com/uploa...1152419322.jpg Bolts now in place and sizes/locations recorded on build chart http://forums.pelicanparts.com/uploa...1152419348.jpg Torquing rods bolts, this was the first time I used the stretch method, these were all set to 0.0120" inches of stretch per ARP specifications: Before with indicator installed and zeroed http://forums.pelicanparts.com/uploa...1152419359.jpg After with stretch indicated http://forums.pelicanparts.com/uploa...1152419371.jpg Completed Crankshaft - whoo hoo! http://forums.pelicanparts.com/uploa...1152419380.jpg |
Well I tried...
But could not seal up the case tonight because I somehow lost the dowel pin for #8 bearing. Had everything laid out and ready and was about to apply the sealant trio...
Crapzola. Anyone got one they can spare? Thanks, |
| All times are GMT -8. The time now is 07:42 AM. |
