Where is this leaking from? Help!!
Can anyone tell me what needs to be replaced in this area. When under acceleration oil comes up from this area (drips when idle or not running). The oil is not coming from the upper valve cover side, but from under the fiberglass engine shroud. It looks like a gasket needs replaced? I can’t seem to figure it out after reading the manuals I have. Any help?
Old 02-20-2006, 01:36 PM
JoeMag's Avatar
the only thing there is the head / cam tower mating surface. it's a metal to metal seal.
i had pic to post but don't know who to do on reply
Old 02-20-2006, 02:19 PM
Forced Induction Junkie
WERK I's Avatar
How does it look from the underside, between cylinders/heads and the heat exchangers?
Also, keep in mind that the fiberglass cover is a point of higher pressure due to cooling fan pressurizing that plenum. Without that cover off, it is difficult to give a definitive answer.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-20-2006, 02:43 PM
Last week I disassembled the air intake etc. and noticed nothing! Now I am having this leak and there are no signs of it coming from the bottom. This is what has been bothering me?? I am taking the intake back off and will post more pics. Still need some help!
Thanks!
Old 02-20-2006, 03:14 PM
