Had rebuild- noisy tappets
Hi had a full rebuild on my 85 3.2 and after approx 600 miles got fairly noisy tappets, is this a problem or should I wait until its fully run in at 1000 miles before having them reset? Thanks.
Old 03-05-2006, 06:46 AM
Did the rebuild include new cams?
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-05-2006, 02:49 PM
No the cams were replaced 10k before.
Old 03-05-2006, 03:09 PM
I wouldn't worry that you have a flat cam then. Drain the oil in the tank and sump and check for particulate matter- anything that would indicate something gone ary. It probably wouldn't hurt to check that everything is still torqued properly and that your valve clearance isn't excessive. These are all things that I would typically do after a rebuild anyways.
Charles Navarro
Old 03-05-2006, 03:26 PM
Try not, Do or Do not
Henry Schmidt's Avatar
It's better to hear the valves in a new engine than smell the valves.
After 1000 mile just readjust the valves. You should be fine.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-06-2006, 08:53 PM
Its when you dont hear them you should worry.
Old 03-07-2006, 03:10 AM
I'd check to ensure there is sufficient oil coming from the spray bars as well...
Old 03-13-2006, 12:18 PM
PJMARKOW's Avatar
Did they replace the adjusters in the rockers. My tappets are still noisy after my rebuild and thats one thing I didn't replace. Other people on this board have had the same problem and the cause was worn adjusters.
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 03-13-2006, 02:51 PM
No the adjusters weren't replaced.
Old 03-13-2006, 03:54 PM
