Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
CBRacerX's Avatar
Name that stud...
I have these studs in the garage from a former race engine that supposedly had a "962 case". I don't know about _that_ but the case was well prepped for the 3.2 race engine that was built. Too bad the builder did not properly torque the rod big ends, but that is a whole 'nuther story.
So what are these? Vintage 1993 or so, and they are not magnetic. ARP or Raceware (likely) or ???? studs? Would like to use them in my 3.8 build.
And just for fun, here are the case studs and some internal studs removed from the engine:
Old 03-06-2006, 03:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Jeff Alton's Avatar
Hmmmmm, the ARP studs that I just got today are not magnetic, nut they have a rounded "nose" on the head end of the stud...
Cheers
jeff@turn3autosport.com
Old 03-06-2006, 06:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
Factory race stud.
I found a set in a 935.
It's almost as nice as my studs.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-06-2006, 07:04 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
CBRacerX's Avatar
Thanks Henry, any special requirements when installing these?
Chris
Chris
2006 CS, 2006 CTT, 2002 Jetta SportWagon, 1994 XJ, 1985 K100RS
Old 03-06-2006, 07:24 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Studs
The studs are Titanium,the cyl studs usually are not but are bright in finish and about 5 mm longer than normal 911 cyl. studs
if they are 935/962 because of the longer cylinders.
Mike Bruns JBRacing.com
Old 03-07-2006, 10:02 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
These studs are the studs we used to design the Supertec heads studs.
We copied the diameter and material then changed the head nut end to a more efficient design. (fine threads)
now the secret is out.
Of coarse there are very few true secrets when it comes to building a quality 911 engine.
The magic is in the quality control.
Henry Schmidt
Ph: 760-728-3062
Old 03-07-2006, 10:53 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
1. Hard to see in the photo but is the shank diameter reduced to slightly less than the minor diameter of the threads?
2. What is the material?
Old 03-07-2006, 01:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Here goes.
Remembering that I am a mechanic not an engineer the specifics are as follows:
17-4ph HCR 38-42 4hrs @ Temp 1025
http://www.latitudemanufacturing.com/174PHPrint.html
Henry Schmidt
Ph: 760-728-3062
Old 03-07-2006, 02:18 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
CBRacerX's Avatar
Thanks again Henry for the detail. Does the installation and torque up process on these differ from the steel versions? For example, should these have anti-sieze in the case vs. locktite?
Thanks,
Chris
Chris
Old 03-07-2006, 02:31 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Blue locTite on the case end anti sieze on the nut and washer end.
Henry Schmidt
Ph: 760-728-3062
Old 03-07-2006, 03:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Are you using the sintered/heat treated stock (98.5% dense) or the wrought stock to make the studs?
Old 03-07-2006, 03:24 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Like I said before "I am a mechanic not an engineer"
I knew it would be a mistake to post the material cart.
Someone always takes the discussion in the direction of unimportant minutia.
I have no idea which material was used. I have a complete material certification but I have no idea how to read it.
Here it is , read it and post your findings.
Henry Schmidt
Ph: 760-728-3062
Old 03-08-2006, 09:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
shbop's Avatar
This started out kinda interesting. OK, now I got a headache!
Jon
911 #303129
81' SC project
70 SS 454 El Camino
Old 03-09-2006, 05:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
CBRacerX's Avatar
I'm still interested, since the details of materials and process for these "simple parts" are things that some of us take for granted. The facts are that there is a LOT of brain power applied to every aspect of engine design, and those folks who have a "better idea", like Henry's custom studs, need to be very careful that the fix/upgrade doesn't cause more harm than benefit. I applaud companies like Supertec who take the time to "do it right"! It would be great if ALL vendors of engine components and services had such a quality commitment.
Chris
Chris
Old 03-09-2006, 05:56 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
The ASTM A484-D5 on the certification papers indicates it is wrought (think "forged") material. The "cert papers" indicate very good material. Sorry if my question came across as minutiae; the earlier link also showed a compacted powder version of the 17-4ph alloy and I was curious if someone had figured out a method of making powder metallurgical high strength fastener material.
By the way it appears that at least for a while the Porsche 911 engine timing chain sprockets (chain wheels) were made via a compressed metal powder method.
Cheers, Jim
Old 03-09-2006, 11:14 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
