hillelson1's Avatar
Send a message via AIM to hillelson1
3.3 turbo rebuilt head cylender gasket question?
hi,
i am rebuilding my first turbo motor out of an 89 930 and i know you guys don't like motor mieter but i called and got some info out of him. Now i just want your guys opinion on what he said. he told me that i should buy his special head gaskets that don't need machining to be put on. is this true or can i just put the motor back to gether the way it was without a gasket? if i do this do i have to prepare it any way?
thanks
-larry
Love cars lucky i got an early start
1989 911turbo project
1928 rolls royce
Old 03-28-2006, 11:34 AM
WydRyd's Avatar
The general consensus is that you really don't need head gaskets. Just make sure both surfaces are prep'd properly, flat and clean and use a good set of head fasteners like ARP and torque them down properly to spec.
I've used C2Turbo head gaskets in my build because I'm told it will handle a bit more torque at higher boost levels (before the heads lift off), but I don't see this happeneing since I've used ARP fasteners. Just extra insurance I guess.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-28-2006, 03:42 PM
