case assembling and nuts....
Hello
shall i consider locking-nuts to apply the right torque on the case assembly ? (peripheral nuts)
what is factory recomandation about this ?
regards
Philippe
Old 03-28-2006, 12:28 PM
3.4 Bigger is better
88-diamondblue's Avatar
Good timing! I will be sealing my case in a few weeks. To add to the question above. Can nylock nuts be used on the case perimeter? Or are the factory style nuts that are deformed slightly the way to go.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-28-2006, 02:21 PM
rw7810's Avatar
I bought the hardware rebuild set from our host. Highly recommend. Mostly uses nylock for perimeter, but a few of the special deformed style lock nuts for some of the interior requiements such as oil pump and other locations.
Robert Williams
70' 911T
Old 03-28-2006, 06:02 PM
Nylock on perimeter is fine. Most of the gasket kits don't have the aluminum crush washers anymore. They have steel washer instead. I don't like them so I use the old aluminum washers. You can also buy the aluminum crush washers (probably from Pelican). If Pelican doesn't have them I bet EBS does.
-Andy
Old 03-29-2006, 10:03 AM
resident samsquamch
sand_man's Avatar
-Andy
FWIW, I would have sworn that the case perimeter washers that I removed were magnetic (hardened steel). My engine had never been apart before. Anyway, I used new hardened washers and new nyloc nuts on my case perimeter.
-jeff
Old 03-29-2006, 10:16 AM
resident samsquamch
sand_man's Avatar
some additional info here:
Can I replacing case parimeter washers?
use steel not aluminum...
-jeff
Old 03-30-2006, 07:34 AM
