Deck height - take my chance ?
Decision decisions...
My deck height measured to be ~0.7mm. That is a bit less than the "well accepted" recommendation of 1.0mm. Would it be ok for me to use it as is?
Some specifics - the cylinder base had been shaved hence the issue. I am already using 1mm stack of base gaskets. I'm putting in ARP rod bolts/nuts, head studs and the car has relatively mild SC cams.
Comments / experience?
thanks.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-08-2006, 10:08 PM
David's Avatar
That's too tight, go ahead and add a 0.25 gasket.
Old 04-09-2006, 05:42 AM
Check out what happened to Synchroid when he went with 0.5mm deck height.
Pistons Euro vs. USA
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 04-09-2006, 05:00 PM
ok - I hear ya guys (& gals)...
My only concern is that I'm already stacking 3 gaskets - 2 0.25mm and a 0.5mm one. If I "shim" it up to 1.25mm, we are talking about "very thick" base gaskets. Will that cause any problems? If I do that, would it be better to get another set of 0.5mm so I'll use 2x0.5mm + 1x0.25mm ones as opposed to 3x0.25mm with the 0.5mm ones?
Old 04-09-2006, 07:57 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
I am running .75mm on my normally aspirated motor with no problem, although I am using RSR style pistons with a mild camshaft profile so I have more than adequate piston-to-valve clearance. We strive for somewhere between .8mm-1.00mm deck height. The tighter clearance may help with detonation issues.
.7mm is getting awfully tight, just to be safe you may wish to add another .25mm shim. If you have 1.00mm worth of base gaskets already, you may also wish to trade in your combinaton of .25mm-.5mm base gaskets for a 1.0mm & .25mm shim. It may lessen the opportunity for a leak later.
If you have the time and are willing to experiment, you can build the long block, time the cams and check your piston-to-valve clearance to see if you have a problem. You may or may not get away with the tight clearance.
At least your smart and checked your deck height, you would be surprised how often this process is overlooked, even by supposed "experienced" engine builders. We sent out quite a few "replacement" Mahle pistons to shops around the country that made this error. You can't assume anything.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 04-09-2006, 08:17 PM
Ralph, any idea where could I get the 1mm base gaskets?
With turbo and the SC cam, I don't think I'll run into piston/valve clearance issues. The cam is pretty mild, but will definitely check.
When I did the top end last time with stock P&Cs, I got 0.9mm deck height and had plenty of piston/valve gap. With everything else in the top end unchanged, I suspect I would be ok if I can get deck height back in the 0.9mm range. Trying to save another dry assembly if I can
Old 04-10-2006, 04:35 AM
I know Andial used to carry them, you can give them a call at 714.957.3900 or better yet, Wrightwood Racing, who imports all of the nice gasket pieces and assembles them in kits to suit your individual needs. Charlie or Rosemary can be reached at 805.385.7191. This is assuming that Pelican doesn't carry them, of course.
Ralph
Old 04-10-2006, 07:11 AM
Irrationally exuberant
ChrisBennet's Avatar
I think with a low deck height you want to be worrying about the piston to head contact more than valve to piston.
Ralph, Wrightwood only sell wholesale last I knew. Not an option for most of us.
Competition Engineering advertises thicker base gaskets.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-10-2006, 10:08 AM
Check with Jon over at EBS - I think he has them.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 04-10-2006, 04:40 PM
Hi
how did you measure the Deck Height and what is your valve to piston (which is far more important)
Neven
Old 04-11-2006, 03:11 PM
There's a tiny bit of chamford (spelling?) on the cylinders, so I measure the height between top of cylinder and the highest point (i.e. flat part) of that chamford area.
Yes, piston/valve clearance is important and I'll measure it. But, if I keep same deck height and the top end did not change (i.e. head, cam, valve, ...) then theoretically, nothing should change from last rebuild. I'd still measure it but will likely take my chance and really assemble it instead of a dry assemably.
Old 04-11-2006, 06:55 PM
David's Avatar
Measure by glueing a little piece of solder (thin solder) on the edge of two sides of the piston crown, put on the head, and turn the engine over. Then measure the squished solder. You may have more clearance than you think.
P.S. EBS has the thick base gaskets.
Old 04-11-2006, 08:07 PM
Hi
so I measure the height between top of cylinder and the highest point (i.e. flat part) of that chamfered area
This is probably not accurate as you are assuming that the edge of the head protrudes beyond the edge of the cylinder, (and the opposite is probably true) Before adding shims I'd do a "solder crush" reading.
Neven
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Kudos for measuring it. As others have said lots of people dont even bother with this step when building a motor and also skip things like cam gear offset. Its funny how you skip things on high priced motor builds. I think your best bet is to measure your height as many times as you are willing to with different methods to get a range and average and go from there. As was said earlier EBS racing sells thicker base gaskets as did/does Andial and some other high end buildiers/shops. The less stacking of gaskets the better for sealing. I havent seen many motors leak from the cylinder bases but I havent been around too many turbo motors. At this point it would really behoove you to go the extra yard and wait a week for an odd sized gasket to show up for the build.
best of luck, cheers!
74 911s neverending story. two feet and a jetta for now.
Old 04-12-2006, 12:49 AM
