cylinder compatibity - 3.0 v 3.2, sealing ring
Hi,
I'm researching a project and trying to decide whether or not to go the 98mm 3.2SS route or just stick with 95mm cylinders. In searching prior posts, I couldn't find a definitive answer to whether cylinders without the sealing ring (i.e. carrera) could be used with heads that have the ring groove machined in them (i.e. SC). Can the SC heads be used as-is on a barrel without the ring groove? Would a sealing ring (gasket) be used or not? Or, would the heads need to be machined to a flat sealing surface? Sorry if this has been answered elsewhere, but not being able to search on 'SC' has it's limitations! Thanks! Tom P.S. - The car is a '78 US-spec targa. Parts acquired so far are SSI's, web cam 20-21's, and heater backdate parts. I would like more compression and maybe more displacement - that's the last major decision to make.
1978 911sc Targa (Sold )2005 BMW X5 3.0i 2000 BMW 528iT (5 spd, sport) 2000 BMW 323Ci conv. (4 sale) 1987 Corvette Callaway Twin-Turbo Conv |
Irrationally exuberant
I didn't think 3.0 heads had grooves in them - just the cylinders.
(If they do have grooves in the head this is going to be embarassing 'cause I've built a couple of SC motors...) -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The heads don't have grooves, only the tops of the cylinders. I see no reason you couldn't use them interchangeably.
72 Carrera RS replica, Spec 911 racer |
You can't interchange pistons though. The wrist pins are different size and location.
-Andy
Doesn't want/need a 3.6L
Ralph |
Thanks! That makes the decision to go big bore that much easier
i would recommend flycutting the sealing surface of the 3.0 heads just enough to get a true, clean sealing surface. they are usually marked up from corrosion, running with a broken head stud or just 30 years of thermal expansion. up to 0.25mm can be taken off, and compensated for with an extra cylinder base shim. don't forget to take the same amount off the outer face of the head so it doesn't contact the outer machined step on the cylinder.
