shbop's Avatar
gasket configuration help
Could someone tell me which way this goes on? Wayne's book cautions that if installed upside down there can be a serious oil leak. It can go any of 4 different ways. Thank you!
Jon
Old 04-22-2006, 06:02 PM
Try not, Do or Do not
Henry Schmidt's Avatar
On a 2.0 there is no wrong way.
Well you do have to get the gasket over all for studs.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-22-2006, 06:15 PM
On my 964, there is a part of the case that is indented to match the extra bump on the inside of the gasket.
-Eric
90 C2
Old 04-22-2006, 06:16 PM
shbop's Avatar
So, the material inside the perimeter is for another application? And just qurious Henry, do you ever use any type of sealant on this or the chain case pieces? I know the book says "no", but this block is 40 years old, and God only knows, how many re-builds. If I had nice new pieces, I wouldn't ask. Thank you!
Jon
Old 04-22-2006, 06:28 PM
We use a thin coat of 574 Loctite.
When I say thin, I mean thin. Just make it wet.
Lay the gasket on a piece of glass and use your finger to wipe the 574 on. Then flip it and do it again.
Henry Schmidt
Ph: 760-728-3062
Old 04-22-2006, 06:42 PM
shbop's Avatar
Thanks Henry!
Jon
Old 04-22-2006, 06:48 PM
